Posts: 1,631 |
Originally posted by sons mechanic: Anybody else have had this problem?
I CURRENTLY have the SAME EXACT problem.
I was too lazy to post here on CEG, even though its been getting worse and worse.
Okay... my problem started with misfiring (it gave me a CEL).
I then bought new FRPP wires and plugs.
Misfire / hesitation went away.
Few months ago I washed and OILED the K&N filter... and at the saem time cleaned MAF.
Okay.. everything was normal.
Few months later (NOW) i've been having the hesitation problem again... and like you precisely explained it feels like no fule is being injected therefore i thought about FUEL FILTER + FUEL PUMP.
Of course... simple things first and i changed fuel filter.
Didnt help.
Talking to some Zetec guys online and they said MAF... but that didnt make too much sense at first... for i just cleaned it 6 months ago....
BUT... since i re-oiled the K&N recently... i think new oil went to the MAF...
I am HOPING thats all i have to do.... this saturday i am cleaning the MAF... again....
If that doenst work... I'll try fuel pump... cause it DOES SEEM like no fuel is being injected.
Another possibility i was thinking about was the coil.
Anything is POSSIBLE... sowing the seeds of love"
Posts: 1,631 |
Originally posted by tiv: Symptoms of an aging fuel pump are increased bucking/hesitation when the fuel tank is below 1/4 level, and power loss at higher rpms (5000 and above).
If that is correct (which I hope it is) I have no aging fuel pump... CAUSE my hesitation is at low RPMs and it happens with any tank level not only when it is emnpty.
also... car runs absolutely normal (at least feels like) on hi-rpms.
Later
Posts: 5,621 |
Yup, that what I thought - when re-oiling some of the oil might have stuck in the MAF. well, that's what I once read in Lance's suggestions. Son's_mechanic: I believe I drove more carb cars in my life than you.  I first drove an enjector fueled car when I was 32 or something.
Posts: 382 |
Originally posted by BBorges: Originally posted by sons mechanic: Anybody else have had this problem?
Didnt help.
I have the same EXACT problem you have but i havent cleaned the MAF or the TB or anything my mechanic has to come because i dont wanna {censored} with my MAF i might break it i already have the TB cleaner can i use that on the MAF? Thats what they told me at Discount Auto Parts
Mods- SVT Kit, SVT Dual Exhaust, SVT Struts & Eibach's, H.I.D's, CTA Intake, Hightowered headlamps.
My 'Tour
Car Club- www.HiProfileCc.com
Posts: 1,631 |
To clean the MAF I use some Electrical cleaner.
It works fine in my case.
Hopefully it is not damaging the MAf in the long term.
Later
Posts: 5,621 |
From what I gathered here (it was posted by ButtonPuncher I guess) I would say that the best way would be not to use any electrical contact no-residue cleaner - but to use a medical grade alcohol and these really thin pipe cleaners - like chenille ones: U might also read Lance's guidelines here MAF cleaning
Posts: 21,653 |
I've been fine with just using an aerosol non-residue electrical parts cleaner.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,143 |
im kind of having the same problem as him, but mine seems to be slightly different, my CEL isnt on as well. The engine hesitates and bucks when trying to accelerate at a lower RPM but tends to go away as the engine gains speed. Im going to try Power cleaning my fuel injector, with 95K miles that 95 tour may need it as well. I might attempt the PCV valve as well. Its supposed to be easy, as well as cheap to do. So couldnt hurt anything.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 5,621 |
AJ - PM me plz them details about power injector cleaning - how much, etc.
Posts: 6 |
Thanks for all of the info guys. I am going to get to work on it this weekend with hopefully some positive results.
I will keep you all posted.
