Page 2 of 2 1 2
sam ething happend to me m just driving and i notice the temp gauge all the way up and the car hasnt even been on for amore than 10 mins driving and like sum sort of smoke or sumthing coming out of the radiator but they changed the water pump for me and everything went back to normal ..
NEW RIDE: 93 NON TURBO SUPRA Black/Blue pearl 97 V6 GL Duratech 5%tint around survivor kit 2 10" 450w pioneer subs and tv kenwood 3way 300w speakers air ride 18's intake my cardomain
Originally posted by mbb41:
Originally posted by contour96:
I have a Duratech...which I have mentioned in my sig.....
Hmmmm I was replying to Apex whom started the thread though.
Sorry didnt know..
Alicia 96 Contour LX 2.5L V6 Duratec Stock of course! BAD ASS GIRLS DRIVE BAD ASS CARS!!! http://www.cardomain.com/id/sweet_ride01
I am Canuckian
I am Canuckian
Sorry didnt know..
NP
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
Apex Offline OP
Thanks for all the replies... I forgot to check back on this... Too much time spent at work...
Still the same problem , mainly because I haven't tried anything on it yet. But now I have something to go by...
'96 Mystique
Apex Offline OP
What engine do you have? On my 96 Zetec the fans don't come on till after the "L". Therefore I'm going to guess that we are talking about the Zetec. For the record. On my car the fans come on @ 211 degrees. That is like I said Just above the "L". As for overheating though? Make sure there is no air in the system. I solved my problem by changing the Thermostat housing and all the sensors. Easy repair and it can be done and cleaned up from in under an hour. Shouldn't cost more then $150 if you do it yourself. Should really be less so shop around for the parts if you choose to go this route. Again. I'm making the assumption this is the Zetec.
It is a Zetec...
'96 Mystique
Apex Offline OP
Originally posted by btrautman:
I had a problem with my ECT sensor. My fans would not come on until the engine was in the upper normal range. Changed ECT and they come on earlier - check resistence on ECT, computer reported mine bad which it was......
What's the ECT ( and where is it located ? )
'96 Mystique
Apex Offline OP
Originally posted by Nate'sTour:
Yeah, what he said! Get that pump changed before you drive it another inch.
The waterpump in on the drivers side, remove the front engine cover and you'll see the belt there on the right. If you remove the battery, you'll have easy access to DIY. Make sure you get a white plastic impeller model NOT the black. If they have metal, that's okay too. But I prefer the white impeller version. Get a new waterpump gasket too.
Are you good with your hands? If so, one look at the waterpump and you'll figure it out.
If the pump is bad once you remove it there might be shards of the old impeller right there in the pump opening. Fish them out as best you can the install the new pump and immediately go to a shop or DIY if you can and powerflush the cooling system to remove any smaller impeller pieces you see.
The cooling fans might not be going on since the system if overheating too fast. The coding of the computer isn't keeping up with the rapid temp rise.
Good luck!!
I hope that's not it...
Thanks for the heads up...
'96 Mystique
Page 2 of 2 1 2
