OK. It only happens when the wheel is turned right it gets quicker with speed just a slight turn in the steering like a 1/2 inch and bam there it is. i can feel it in the pedals and the pasenger can hear it as well. ive tried swiching tires around even useing the spare on both sides one at a time. the sound is like a mud tire hum going down the road if the wheel is strait or going left it goes away. please some one give me some tips or beeter yet tell me you have expirenced this and kwow what it is thanks any input is greatly welcome. oh yea i have stock svt wheels and stock size tires stock suspenstion but bat cross and grooved rotors.
blk 1998 svt contour custom paint by taylors house of color sho y pipe and hi flow converter fms 9m wires open element filter and sloted cross drilled roters
N
N
It may be a rubbing going on. Have you checked the inside of each wheelwell? To see if you see any contact points. Look for something shiny, or unusually clean to indicate a point where the tire is rubbing the inner fender or wheelwell somehere.
That will be a good start.
good luck!
yes and no rubbing i even tried the spare on each side. you dont even have to turn the wheel but a tiny bit to the right. thanks for the reply though
Zippy Zetec on his last legs.
could be a few things, but it sounds like a CV joint, though i cant say for sure without hearing it.
Regards, Cole. Relegating to troll status sometime this week. New Whip: 1990 Lexus ES250. Old Hotness: 1995 GL MTX Zetec *IN TRIAGE* "I had a little friend once, but it dont move no more... "
well at least that gives me something to tell a shop to look at the car is 6 years old and 145000 miles. but would it only be noticeble turning one way the car handles fine like the day i bought it with 33 miles. and would the sound get faster with more speed.
wheel bearing/CVjoint. could be both at the same time.
cool i could handle the bearing job my self but the cv joint is a problem. i appreciate the help and replys. any one else got any ideals or input
ok i just read another post similar to my problem do you guys think that the allinment shop could have screwed something up since i had it done only about a month ago. and if so what maybe some thing loose or broke
yes its possible, if your alignment is off just slightly, it could cause only one side to rub during a turn.
True. But the spare on each side one side at a time made the same noise. So i dont think rubbing is a issue.
