#979114 06/13/04 01:22 PM
Mark 77 Offline OP
When the car is in Drive and i'm standing still at a stoplight or something and particulary with the AC on, the car shakes and sounds rough. It suddenly stops and then comes back on again. I gues it has something to do with the AC being on, but it sometimes dous it without the AC too, is it the cooling fans or what?
Mark, Contour GL 2,0 ATX, -98
#979115 06/13/04 01:38 PM
with the engine running and the brake on and the A/C on you have the engine overloaded... that is why the computer will
raise the RPM's up.. but you will not see it or feel it....
it reallly does not raise the RPM's up it just give it a little more gas to keep the RPM's at its normal rate about
800 rpm's so the car will not stall... you might have a problem with spark plugs, wires, etc or the IAC and it is not keeping the rpms's high enough to take car of the engine to keep it running fast enough.....
