Posts: 2,683 |
Didnt really make much difference to me,lost that annoying bogg when the secons opened,but the engine kinda bucked when driving at a steady pace at any RPM. It felt kinda strong but couldnt tell if it help or hurt performance. Then when I went to the store and came back out and started the SVT the CEL lit my face up. So I undid it all but still have the lovely orange glow on the dash. :rolleyes: Will it clear up on its own?
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Administrator
Administrator
Posts: 702 |
It may be coincidental...
I've not heard of the IMRC module causing CEL's.
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 2,166 |
Bad IMRC module won't cause a MIL. Maybe its running lean or detecting a missfire. FSM states ecu doesn't have any checking mechanism for the MIRC.
Posts: 2,683 |
I wonder what it could be? It seemed to run fine with the exception of no surge of power at +-3700RPM.It bucked slightly,barely noticeable. I took the ties off after I got home,and now the car runs just as it did before the tie back,but the CEL is still glowing.I never unpluged anything,and it didnt come on right away only after the second start up after the tie up. Damn now I gotta Go see the dealer,that bites.Any manual way to check the CEL?(jumper wires like in the Volvos?) :rolleyes:
Posts: 2,683 |
Originally posted by David Z: Bad IMRC module won't cause a MIL. Maybe its running lean or detecting a missfire. FSM states ecu doesn't have any checking mechanism for the MIRC. Are you sure about that,I thought some had went to the dealer for a CEL and it turned out to be MIRC related?
Posts: 1,773 |
Lance is right, for vacuum actuated '95, anyway...
David Z, that may be true for contour PCM, but in general at least there is a bunch of codes associated with IMRC. P1512 Intake Manifold Runner Control Stuck Closed. P1513 Intake Manifold Runner Control Stuck Closed. P1516 Intake Manifold Runner Control Input Error. P1517 Intake Manifold Runner Control Input Error. P1518 Intake Manifold Runner Control fault - Stuck Open. P1519 Intake Manifold Runner Control Stuck Open. P1520 Intake Manifold Runner Control circuit fault. P1519 Intake Manifold Runner Control fault - Stuck Closed. P1520 Intake Manifold Runner Control fault.
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
Posts: 3,562 |
Originally posted by At a loss for user name: Any manual way to check the CEL?(jumper wires like in the Volvos?) :rolleyes: Not on a '96+ tour. '95's you can do the jumper thing though. I say clear the codes and see if it comes back. Under hood fuses 4 and 11 IIRC...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 2,683 |
Originally posted by bnoon: Not on a '96+ tour. '95's you can do the jumper thing though. I say clear the codes and see if it comes back. Under hood fuses 4 and 11 IIRC... Thanks Brad,I knew I could pull a fuse but just wasnt sure which ones.You saved me,time and frustration!
Posts: 2,166 |
I'll have to look it up in the FSM.
A while back I was fooling around with the IMRC and I couldn't get the PCM to show a MIL. Then I read it in the FSM that there is minimal interaction between the PCM and the IMRC box. But who knows, I'll have to check...
Posts: 434 |
It could be running dangerously lean at start-up! Why you ask? Because the stock ECU fuel maps are programmed for x amount of air at idle and below RPMs when IMRC isn't actuated. However, you are now starting the car with xx (twice as much) air as it is programmed for. This will lean out the mixture quite a bit and could cause some damage if that is what the CEL is for. Get an AutoTap or ODB-II scan tool before doing anything like this again. Without these tools, guessing at what causes a CEL is about as accurate as finding a needle in a haystack.
