Posts: 1,960 |
What are they for ?  They're plastic lines, like a vacuum line. One goes all the way up and into/under the headliner, the other stops halfway up the A pillar and is covered with a little piece of foam. I was hardwiring my radar detector and I noticed them in the process of doing that.
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 2,007 |
Drains for the sunroof, you got two in the back as well, on the c pillars.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 1,960 |
Posts: 2,007 |
I have no freakin clue then.
I know on my car i have 4 black hoses at each corner, i read on here once that they were sunroof drains...
How thick are they?
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 1,960 |
I uploaded a pic to my profile. When it's approved, you'll be able to see it. Very unusual.
Posts: 1,960 |
Click for a pic. The dangling cord is the power cord for my radar detector. Anyone got ideas ?
Posts: 4,693 |
It's the antenna for the GPS unit your parents put in the car so they can tell when you have been speeding. . . . and where you have been spending your time.
Really, I don't know what it is. Can you trace the line to the other end to see where it goes?
Jim Johnson
98 SVT
03 Escape Limited
Posts: 21,653 |
My only guess is they can somehow remove moisture from the car.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 4,639 |
i thought the black one was the radio antenna cable that runs up the apiller to the top to the back and down the cpillar to the antenna. the white tube i have no idea. maybe it is a sunroof drain. my car is an mtx and i have the atx plug tucked away under the carpet to the left of the mtx shifter
Hugo AIM:omegazodiac
Posts: 136 |
I work for Ford and have seen some funky things.  The black one is probably a sunroof drain tube even though your car dosen't have a sunroof. I have no clue what the clear one is, just try to follow it to the other end, could be some kind of HVAC case vent.
