Posts: 107 |
Has anybody else had this this terrible noise problem when they open this door. I have a 95 and 2000 Contours and both have it. White Grease will not help.
Posts: 58 |
I had this problem, I greased the hinges, and the hinge check. I believe the hinge check inside the door was the culprit.
Posts: 2,382 |
Passengers door on drivers side? That's impossible...
Do you mean the rear drivers door? If so, then yes I have it too. Since that door is seldom if ever opened it's so tight that it seems newer than new..
I've put some grease on the hinges. Not WD-40 which is more a penetrant, but grease.
"Fear is the little death."
Muadib.
Posts: 496 |
Maybe if "you" said, rear "divers-side" door, your explanation would make more sense. I think his description of the door is very good.
Posts: 2,445 |
I keep a bottle of spray lubercant handy as my hinge checks need greasing every six months or so. I usually spray the hinges at the same time just for kicks.
I am beginning to think the doors are sagging a bit which would make the hinge check rub it's guides a little more.
2000 Contour SE Sport
Originator of the Beowulf Headlight Mod and the Beowulf CAI
Posts: 107 |
Thanks to all but what is the hinge check? And what type of grease do you recommend since white grease didn't work for me.
Posts: 362 |
I used some graphite spray. I bought it at an auto parts store. Its a small can and it works. I had the same problem on all my doors.
Yeah, I'm a troll...
2000 Saab 9-5 SE
2003 Dodge Neon SXT
Posts: 839 |
I have the same problem on the same door. I tried some WD40 but gave up after that.. I don't usually have passengers back there.
The Spickle
New Car: Infra Red '04 FSVT
Former Car: Black '98 CSVT, #3137/6535 "The Unluckiest car.. ever"
Posts: 2,445 |
Originally posted by SpliceVW: I have the same problem on the same door. I tried some WD40 but gave up after that.. I don't usually have passengers back there.
WD-40 is a terrible lubercant for things like that.
Wait, WD-40 is just a terrible lubercant and a half decent penetrating oil.
Posts: 107 |
Beowulf, do you agree that graphite is the best lubricant for this problem?
