Page 6 of 6 1 2 3 4 5 6
So if the 65mm Mustang TB works, why stop there, any reason a FMS GT 70mm TB wouldn't work?
nevermind, I just reread that the 65mm matches the bore on the intake manifold.
-Louis
1998 Black E0 #3826, lightly modded
Yup...the 65mm matches the bore of the SVT manifold, but is significantly larger than the bore of the Cougar/Contour SE manifold, so some port matching is required if you expect to see any gains out of this...
Nikolas
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
I have a few 65mm throttle bodies that I have posted in the classified section. I could let them go for cheaper than $65.00. Sorry if I posted on the wrong forum.
justSVT My Tour is a cross breed.
after reading the threads on this subject there is still no real proof that a larger tb is the way to go so why do standard duratec owners fit the 60mm from the svt. again has anyone dynoed there standard duratec after this mod. i have a few questions:-
1. does the MAF SENSOR have a max cfm?
2. how does it compare to the CFM OF A 65mm or 70mm tb?
3. what is the max cfm the standard ECU can compute?
4. If the ECU can make ajustments (learn the optium settings) why do people fit superchips(is it because the ajustments are made from a premaped AFR map etc and not reprogrammed in real time)
5.how much fuel is need at WOT (max airflow cfm N/a for 65mm or 70mm tb) to keep the mixture at 14.7 and are the ejectors capable of delivering that much fuel?
i think the ECU is premapped with thousands of vairables based on the original setup. increasing the size of the TB is not a vairable preprogrammed into the ecu. i mean forinstance if you fit a powerflow MAF you have to tell them about the mods you have done so they can calibrate the MAF for you setup. wouldnt this be true of the stock MAF? i belive that there are some gains to be had if a 65/70mm TB is fitted along side a preformance MAF and of course a performance exhaust as i beleve the ecu is geting bogus info from the o2 sensor as it cant get a true reading of the gases on a standard exhaust using a larger TB due to the fact it is so restricted. anyway thats my opinion, ps i know i cant spell its geting late in the uk (01.00am) confused
Mondeo ST24 with RSAP body kit.
17" DOTz's on 215/40/17 goodyear F1's (very good tyre)
EBC TURBO GROOVE FRONT AND REAR DISCS (rotors)(warped fronts exchanged under warrenty)
EBC GREEN STUFF PADS (voted no1 in uk performance ford tests)
k&N induction kit
throttle body butterfly mod
SHM HEADERS, Y & CAT
Custom Exhaust System
Ecotec Valve
more mods to come...
ice sony XR-M510 head unit
sony 656 changer(cdr/cdrw/cdtext compatable)
