Page 4 of 6 1 2 3 4 5 6
Originally posted by Rara:
Stazi, brad's right. btw, if I read your post correctly (I read it quickly) you basically described a speed-density system, not a Mass Airflow system.
I was thinking the same thing....Brings me back to the Mustang Speed Density vs. Mass Air topics over on the Corral.
Regards
1998 SVT Contour E1, Black
2001 Honda SuperHawk VTR1000F
"I bent my Wookie"
www.mamisano.com
ttt
I like this topic laugh
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
Posted by Aussie SVT
"The torque increas with this mod is AWESOME. Part throttle and up to 3/4 throttle is totally like night and day compared to the SVT throttle body."
Was thinking about this. I dont exactly see how the big T-body would help at less than full throttle. Unless, the big butterfly is just really only allowing more air in sooner, equivalent to pushing the gas petal further. Some companies do with their throttle cables - basically a little throttle motion leads to a big throttle opening and a PERSEPTION of more low end power/incraesed throttle response. Could this be occuring here? Be real interested in seeing dyno proof sometime of this mod.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
What additional mods do I need to do to my car (95 non-SVT V6) to make this work? My throttle cable goes over a black plactic cam and then attaches to the throttle cable. It looks, from your pics, that your cable goes under this cam. Is this right? Will I need anything SVT specific to do this?
Could you post some pics of the throttle lever/cam/cable with the throttle closed, at 1/2 throttle, and WOT; so that I can get a better idea of what is going on here?
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
You need and SVT cable bracket that hold the Throttle Cable and CC Cable to make this work on a non-SVT.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Ok, thanks, you don't happen to have a part number, do you? Was I right about the cam? I am guessing that it is the same throttle and CC cable, though?
DMD Installed
SVT Brakes
I don't know the cam orientation/setup on non-SVT contour, but if indeed it DOES go firstly over the top of the cam then down and around, then you may not have to clock the throttle shaft and cam. But without seeing the setup, I am going in blind.
Regards,
Anastazi
You need the SVT throttle cable and bracket. The CC cable remains the same. Also, some early SE's had a different connector for the TPS which you may have to adapt to attach to the 'stang TPS.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
I hope the installation is pretty straightforward. I can see one issue being the gooseneck assembly. I better take it off or something and stretch it somehow and be careful not to tear it, to make sure it fits over the larger TB now. I didnt want to buy a new one of those either, they are just wayyyy too much money...
Nik
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Info I got from Bill Jenkins
Part number F4SE-DB crosses over to a F7SZ-9E926-AA, and it fit's the regular 4.6L in the T-bird, Cougar, Crown Vic, Towncar, G. Marquis.
F7SZ*9E926*AA BODY List $212.70 CEG $138.26
When doing this Mod you may get really bad throttle hang.
Fix it by adjusting the air bypass screw, all the way down, next to the TPS sensor (allen head in the pictures).
Found a dyno but 125 per hour is a little high.
