On a Zetec
What if you bank a turbo off of Piston 2 and 3 only.
Would it work?
Manifold cut, custom pipes from 2 and 3 ran to the right, batt & holder removed and in trunk, custom plate, into turbo, turbo to frontmount.. etc.
Or would this have adverse affects?
The reason for only using 2 and 3 is they move at the same time. Less boost ability, but same outcome in the long run, less stress.
It would be like a loop, and since the waistegate and bov dispose of exhaust, then it would not be contained closed, ovbiously. Along with 1 and 4 Routing to 2.5 inch exhaust, with highflow cat at resonaters spot, and 1 chopped SVT outlet.
Im only talking a small turbo, off of a TSI talon, or so, with about 2 - 3 lbs and maybe 5 lbs, but 10 to 1 ratio is bad bad bad...
Would the stock internals take 2-3 lbs? an ocasional 5?
Or would wet nitrous 35 - 50 be a better alternative.
Based on:
Saftey of the car mechanically
Eficiency
Assuming cost isnt included..
Just an idea..
Ill go ahead and
myself, incase anyone else wants to. lol, I was thinking about it.. While im stationed in the air force, id have time to work on my car, and im determining if I should do a Nitrous setup, or a Small turbo for fun..
