Posts: 3,237 |
Well on Wednesday evening I installed my 65mm GT Mustang throttle body onto my SVT Contour. The installation was pretty easy with only a couple of mods needing to be done to the Mustang TB for it to work with the Contour setup. First thing I did, which I actually completed the day before, was to clock the throttle shaft and cam through 180° so as to have the cam in the same orientation as that of the SVT's. To do this you need to follow these steps: First unscrew the TPS and see how the tab on the end of the shaft is orientated in the TB. Make a line on the TB in line with the tab(scratching the Aluminum with a screw driver, lightly works well). With the TPS off, keep you sticky fingers to yourself and don't screw around with the TPS, don't move the mechanism or you may put it in the wrong position for reassembly. To clock the shaft you unscrew the butterfly from the shaft 2 screws insode the TB bore) and then slide the butterfly out. Next pull the shaft out (remember it's position b4 you do). You will have to grind away some Aluminum from the dead stop on the TB. Take of 3mm from the edge (see my pics below). Then rotate the shaft 180° and slid back in. You'll have to get the spring on right and turn it through 360° in the opposite direction to get the preload on the spring. Then reinsert the butterfly. You will now see that the butterfly open ands closes like before BUT the cam for the throttle cable is upside-down like they have it in the Contour. Finally reinstall the TPS. To install onto the manifold I bought a new gasket for the mustang TB and reused the Contour gasket also. At the top of Contour's gasket I used a little RTV to help seal it to the manifold as the GT TB doesn't press up against the arch like the Contour TB (see pic). This is due to the different setups that the Mustang have for the EGR ports. The gasket off the Contour TB has to be trimmed ever so slightly around it's bore ID, and I also removed the bump (you will see what I mean when you do this mod) in the ID all together. The bracket on the throttle cam also need to be trimmed in one spot, and bent it another so as to clear the intake maifold in one place and act as a positive stop for the butterfly in another. The last thing to do ist install the TB onto the manifold, using both gaskets, with the Mustang gasket against the Mustang TB and the Contour gasket against the manifold. The bore of the manifold and the 65mm TB are pretty spot-on, no grinding is required to port match the two. The last thing is to hook up the throttle cable, and you'll find that the lead knob on the end of the cable is slightly larger in diameter than hole in the throttle cam, but with a set up adjustable pliers it can be pushed into the hole. The torque increas with this mod is AWESOME. Part throttle and up to 3/4 throttle is totally like night and day compared to the SVT throttle body. I love this mod, and for the money you can't beat it. I think you have to have good exhaust and intake mods though to really feel the benefit of this mod. For those who like engine noises, the sucking and whistling with this TB is prolly 75% louder, sounds COOL! Anyway, check out the pics and let me know if you have any questions that I may be able to answer. My optimised intake! In this pic you can see that the bracket to the right of the spring has been cut flat. This is to clear the upper intake manifold, BUT the diagonal looking brack it bent outward to stop the butterfly (by hitting the manifold) at a point where the butterfly is flat. This shows the positive stop better. In this pic you can see where the bracket to the right of the spring has been cut flat a little better. Finally you can see where the tang on the throttle cam plate has to clear the TB casting, and thus the need to grind some of the casting on the "old" postive stop, off so the buterfly is unrestricted through its 90° of movement.I recommend this mod to all modded SVT owners. You WILL NOT be disappointed!
Posts: 1,841 |
I might have to get with you on this one....
"I sense much beer in you.... Beer leads to intoxication, intoxication leads to hang over, hang over leads to suffering....., suffering leads to the dark side." -Chineseman 3:16
Steve Chang 99 Silver SVT #196 "ExtrudeHone" Sponsored by Street-Concepts 174.2 fwhp @ 150.7 ft/lbs (218 hp @ crank) - Pre-Headers SVT/SHO Society Vice President XChang Designs
Posts: 1,050 |
Great job with the pics and explanation...
Nice set up
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
Posts: 2,025 |
Originally posted by xchang: I might have to get with you on this one.... Wow, along with what you just purchased from me?  How fast are you looking to go?
1998 SVT Contour E1, Black 2001 Honda SuperHawk VTR1000F "I bent my Wookie" www.mamisano.com
Posts: 165 |
sounds awesome, can I do this on my 97 SE?
5 speed MTX /KKM Custom Intake /Dynomax Super Turbo /TH Fix /Audi A6 Sidemarkers / Badgeless /Audio:(JBL600.1 amp,Polk Dx Subs, Infinity 6953i 6x9's, Lightning Audio Strike Cap)
Posts: 3,562 |
Originally posted by MTXcontour97SE: sounds awesome, can I do this on my 97 SE? Nope, '97 is the only year you can't do it on :p. Kidding. You will need the SVT cable brackets is all, then follow his write up. I have one ready myself, but then that darn bearing had to spin... glad to see it works though without to much effort.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 265 |
Nice Job Aussie!
Tell me - you didn't have to shorten the throttle cable or don't have any problems with the throttle range being a lot shorter?
dan
Posts: 3,237 |
dan No shortening required. Actually the butterfly can go past 90° if you don't adjust the dead stop to prevent it from doing so. I didn't have to hack anything up from my stock equipment. Only thing that was touched was the ID of the gasket.
Posts: 1,841 |
Originally posted by mamisano: Wow, along with what you just purchased from me?
How fast are you looking to go?As fast as I can!!  I'm looking into a 3.0L, bumping compression to 12.5:1, some upgraded race parts *kinda like David Z*, the Ford Racing LSD, Terry H's Bulldog tranny gears, and some other little gadgets. I want to push 300hp by the time I'm done, but keeping it Naturally Aspirated... maybe.
Posts: 3,248 |
Sounds interesting. Can you tell me what year Mustang GT the 65mm T-body is off of or a part number? About what does it cost? Thanks.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
