#974408 06/08/04 04:47 PM
I replaced my air conditioning compressor and refilled it with oil refrigerant etc. Everything is working fine but it does not cool as fast as it should nor does it get as cold as it should. Did I miss any key parts that should have been replaced along with the compressor?
cta intake essilenger udp odp 9mm ford racing wires hp accel coil custom fog lights svt kit with micahs pre98 svt bumper 17 inch speedy holotype wheels 215 45 Ventus HRII tires custom wood dash magnaflow exhaust
#974409 06/08/04 07:50 PM
H
H
Did you have any metal in the lines that you didnt get out?
I notice people say not to do that yourself because you may get metal in the lines.
#974410 08/10/04 06:41 AM
Did you vacuum the system out and change the filter/dryer?
96 Contour GL 2.0L MTX with Early SE 7 spoke wheels, SE sideskirts, Koni Sport Kit 70 Mustang Sportsroof with mild 351W and '01 Mustang GT wheels
#974411 08/10/04 06:16 PM
E
E
I'd have to say that it's because you didn't vacuum out the system and there is air in the lines. I just did my compressor clutch this past weekend and I had to remove the compressor to get it off. I had my system vacuumed and recharged and it blows real cold.
95 Gl Zetec Atx
