Well, I'd been contemplating this mod for awhile, since I didn't know if you could get wheel adapter to put nice steering wheels on airbag-equipped cars like my 'tour. I originally wanted a quick release wheel though, so I could use my laptop computer to check my email, and surf comfortably while I wait the 1/2 hour everyday for my wife to get off work (we carpool to our jobs since we both work close to each other). So to accomplish my goal, I do some research. I found out that Focus uses the same (almost same hub) as Contour. And Focuses are popular to racers in Europe so aftermarket hub production is plentyful for those cars. So I got me a Sparco/ Ford Focus hub from here: http://www.9secondracing.com/cgi-bin/search.cgi?partnum=10579 and guess what? The hub DID fit (with a couple mods so the steering column shrouds would fit back on, and mod to make the turn signal cancellers so they would be able to work like OEM).
I used the special quick release hub adapter from here: http://camp1320.com/parts/interior.html and I did the whole project similarly based off this 3 page forum string (has pics of quick release hub) seen here: http://www.honda-tech.com/zerothread?id=749748
This hub only accepts the MOMO 6 bolt steering wheel or the Sparco 6 bolt steering wheel, but WOULD NOT accept the GRANT 5 bolt steering wheel, so I made an adapter so the wheel that I REALLY wanted would fit my setup (had perfect style and colors matched perfectly). The adapter I made is only a 3/8" thick spacer that I machined on a lathe and it has 6 countersunk allen bolts in it to bolt to the quick release coupler, and it has 5 threaded bolt holes it the spacer so the Grant wheel can bolt right to it.
And to get the Focus hub to work I had to chaulk it up on the lathe an turn the hub's outside diameter down so it would fit under the stock plastic shrouds that go around the steering column. Then I had to hand Dremmel out a 1/4 deep groove around 80% of the circumference of the hub (at the base right where the finger from the turn sig switch lines up to it), leaving a 1 inch section of the circumference uncut (centered at 9 o'clock position) so the turn signal cancelling finger had a catch to cancel it out when the signal is on, and you return the wheel back to center.
Anyways, all this went so nicely, that I thought I'd post pics in case anybody else wanted to try it.
This new wheel totally rocks though! (not literally- The quick release hub is very tight and has no slop in it at all). That was one of my initial concerns with addng a quick release hub was how tight it would be at the coupler, but it does fit nice and tight. And the new wheel gives the car a WHOLE NEW FEEL to it. The smaller diameter increases steering effort by a noticeable amount so as to give the car more of a performance feel when cornering around hard. Definitely more road feel now. Also, the wheel is molded to fit your hands much better, and I feel I have way better control of the vehicle now, which will help avoid wrecks, so this justifies the removal of the airbag, since I believe more vehicle control will result in a safer vehicle, reducing the chance for collision.
Anyways, on to the pics:
'95 CONTOUR SE -Enkei 16s -SVT wannabe -Dual escapes w/ 2 1/2" stainless tips -True LED taillight conversion -Audi Xenon Projector Retrofit -Mp3 deck, dual 10s
props for originality. first in a contour as far as i know. all you have to do now is vaccum that car out!!!
*I'd rather be a smart ass than a dumbass www.fast4doors.com
thats kinda cool. dont know what purpose it serves in a car that doesnt need 5 second driver changes but its cool none the less.
guess you could look at it as insurance against theft. that is unless they have another steering wheel handy.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
I
I
and use it for a keychain.....less chance of loosing his keys
wouldnt it have been easier just to sit in the passenger seat and play on your laptop???
E1 CSVT s/c-----x turbo---x 3L------check
LMAO!
Dang, Josch. Now my stock steering wheel looks all fat and clunky to me. Before, I liked it just fine.
Master P
Master P
I think you need to vacuum your car
I know Dion has/had an aftermarket wheel..
V
V
Definitely original. I keep switching back and forth on whether I want do this or not. We'll see, I guess.
What about the airbag light? Is it constantly on now?
-Chuck Dienzo Black 98.5 E1 SVT #5022 of 6535 Born on March 16, 1998 "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Yeah, yeah guys, I know, you caught me. I didn't even think to vacuum the car out before whore'n it off so quick. I live out in the boonies where it's all dirt roads and it's hard to keep a car clean (that's my story and I'm stick'n to it).
As for airbag light...It blank at first, so I took out the bulb...Then with the resistance of the bulb gone and that circuit open, this really loud annoying audible alarm wouldn't stop going off from the airbag brain box...So I just unplugged the harness connector going to that module which made the noise quit for good
i wish i had that when my mustang got stolen 4yrs ago
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
