BP Offline OP
I need some advice here. I would like to get more performance and sound out of my exhaust but I'm not interested in the duals.
Can you guys suggest any single exhaust systems?
I've got a kkm but am stock otherwise. Also from what I've been able to gather from the discussions here it may not make much sense to remove the resonator. Any truth to that if I upgrade the muffler?
TIA!
-Brian-
98 SE DTec MTX
Best bang for the buck by far, especially if you don't care about going to dual outlets is to just go to a muffler shop and have them replace your stock muffler and resonator with high flow units. As far as the res goes, have them replace it with a glasspack, or the drone will drive you mad.
While you may not get the absolute peak hp gains you would with an entirely new system using larger tubing - you will get a nice boost in overall power at a great price. IIRC, some of the cougar folks run something like this and report very nice torque gains.
hth,
dan
Ugh there is no drone guys! I have had this setup for over a month and there is no drone on non-SVTs. The SVT is known for bad drone. It is a good idea to have them simply weld in a straight pipe. Email me and I'll send some sound clips. The performance gains are minimal if any, but the new sound is great! Draws lots of looks!
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
TheContourGuy, You have mail laugh
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
I
I
I replaced the Stock Ford OEM muffler with a Dynomax and removed the resonator while they were at it. No DRONE!. Nice increase in power.
98 Contour LX V6 Mtx
N
ngm Offline
N
For now, on my '99 SE, I replaced the resonator with a straight pipe (not a glasspack) and the stock Ford muffler with a Ravin'. I do not have the drone problem many have complained about. The only negative being that until the system heats up, I do hear a "4 cylinder, high pitched" whine at 3000 rpm and 4500 rpm. Again, when the engine is cool, at full throttle this sound occurs all the way to redline. But, fortunately, this obnoxious noise disappears completely when the engine and exhaust are at operating temperature.
Eventually I'll add a second Ravin' with a custom cat-back system. I'm pleased with the sound and can detect (seat of the pants!!) an increase in hp and torque.
FYI>>>>>>>I have a K&N drop-in air filter and
experimented with removing the air box completely, and with leaving the entire air delivery system intact. While at high rpm's I cannot notice any major power difference, at low rpm's I can feel (again, seat of the pants!!!!!!) a power increase by leaving the stock air box unit connected. Without the airbox, the filter apparently sucks in too much warm air from the engine, decreasing power. Now, I'll have to experiment using additional ducting to the airbox to see if there is any additional power to be gained.
Nathan
'99 SE 2.5 w/mtx
-custom graphics & windshield banner
-badging removed; knauberized doors
-K&N filter w/ secondary 2 1/4" inlet to stock air box
-resonator removed; replaced with
straight pipe
-Ravin' muffler
-sail panels painted
-Cooper Cobra GTZ tires
(205/55/R15) on stock ES wheels
-custom chin spoiler
9
9
Nathan
I hope you don't mean that you were driving around w/o a filter on--- that would be bad
eek
97' 2.5L Contour SE -T-Red
Midas exhaust (grr...), Sony CD player, K&N airfilter, Mobil One Synthetic Oil, removed intake resonator, modified MAF, in-fender CAI, painted grill, Platinum tipped NGK's.
I am looking for SVT E0's or E1's, SVT Upper & Lower Intake, SVT Throttle Body, and SVT Exhaust. If you are selling, e-mail me!
Ford4eva@hotmail.com
Where did you get the ravin muffler?
Ben C
'97 Zetec Sport ATX
Pacific Green
Fog Light Re-wire
Many Mods
My Site
You think you can beat this?.....Well, you probably can
I have a delta 40 series flow master and a glass pack where the res use to be and I love the sound. real deep at low rpms then it gets guite as the motor revs or at the the intake is louder. Hope this helps
Eric
99 SE MTX
Flowmaster muffler, no Res, Weapon r filter, 80mm mustang mas, Air/fuel guage, oil pressure guage
2 pod guage pod, B&M shifter, Hyper white bulbs, white front corner lights, Mobil 5w-30 syn,
K&N oil filter, Air/Fuel optimizer
SVT throttle body real soon!
14.7 @ 92 Best time
15.2 @ 93 Best MPH
I
I
number one Contourguy u still have the stock muffler out back,, so thats y u dont get droon,, i replaced my res with a ultraflow and out back i have a magnaflow and i love the sound... when i had the bullet in place of the res and the magnaflow i was getting rasp and droon.. sucks u dont want it.. i would recomend either getting a flowmaster(40 series0 or magnaflow both of these are str8 through mufflers cant go wrong..hope this helps heres a pic of my muffler..
[img]http://albums.photopoint.com/j/View?u=1666929&a=12778562&p=47744604&sequence=0[/img]
