Page 2 of 3 1 2 3
#97339 05/30/01 03:20 PM
Twin turbo is not going to happen. The rear bank is too close to the firewall. It would take major mods to move the sheetmetal, and it would have to be a liquid cooled turbo. As for a single turbo, that is possible. Relocate the battery (like for the SC install) have headers done up, and go from there.
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
#97340 05/30/01 05:09 PM
That car looks similar to a Lotus Elise. Anyone else think so??
'99 SVT Contour
1298 of 2760
#97341 05/30/01 11:19 PM
V
V
i agree.
1998 E0 Ford Contour SVT
Built on 8/19/97 -- #3101/6535
Silver Frost/Midnight Blue
* New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
#97342 05/31/01 12:14 AM
I want a mid-engine car with a duratec!
#97343 05/31/01 12:21 AM
now that i think about it, that car *really* should have upwards of 400bhp. I mean, twin turbos... If you're going to build a whole chassis, why not beef up the internal goodies so you can run 14 lbs of boost?
#97344 05/31/01 05:00 AM
F
F
That car has internals ... I am assuming that due to it's rediculously low weight, anything more would be overkill. Terry can tell you ... he made a commnent once about the build quality of that car if I am not mistaken. He needs to take a break more often and come back and post on the this board smile
Best Regards,
Trevor Cole
New Edge Cougar Forums
#97345 05/31/01 06:15 PM
what about running the second turbo in series and not in parallel? i bet you could squeeze one in that way, if you really want to run two... as far as terry, i am not one to comment on his behalf, but i believe his absense from the board is due to family matters...
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
#97346 05/31/01 06:38 PM
F
F
I just assumed that he had his head burried in projects and couldn't get to the board, or lost interest because he was too busy ... his input is greatly missed frown
Best Regards,
Trevor Cole
#97347 05/31/01 10:50 PM
The horsepower rating for a european duratech is 167 hp. I think that it's pretty ipressive that they went up to 310 hp. I believe that the guy who ownes the company used to be a designer for lotus, so that's why they look the same. I e-mailed them some time ago about details of the internals, but never got a response. frown
-James
SVT with CE light mod and a camera mount.
Naughty Pictures
Why yes it is true, I am on my third engine.
#97348 06/01/01 12:06 AM
I think the Judge is correct. The major problem will be packaging the turbos. Room under the hood is tight and the best performace will come if the turbo is very close to the point where the ehaust exits the engine ... otherwise you loose heat (energy) needed to drive the turbo(s).
The second packaging problem involves routing the air from the turbo to the inlet. Too long a path will contribute to lag. Finally, you probably will want an intercooler (compressing air adds heat)and where the heck are you going to mount one?
If (and that a big if) you solve the above, you still need to conquer the same problems as the Vortech crowd with boost limits (6 or so psi will probably be OK, more boost = more power = more of a chance for things to go BOOM) and the inherent limits of no limited slip, somewhat marginal clutch, and weak transmision
So, at this point, the best forced induction choice is the Vortech .. one compressor to package and the engineering has already been done. Purists will argue the relative merits of a turbo over a supercharger .. that's not relevent her ... packaging is the driving factor. Want a turbo? Down-size to a Z-Tec, put in 8.5 to 1 pistons, O-ring the head, add a turbo (about 14 - 16 pounds of boost sounds good), add an intercooler, and then beef the transmission and drive train. Or you could buy another car!
Gramps
(yes I got rid of the 'tour for a Maxima but I'm still lurking around)
Page 2 of 3 1 2 3
