Page 2 of 2 1 2
Hey thanks Rio for that info. Have you had a chance to get a dyno run/g-tech/1/4 mile times that show that the Flywheel really made a difference or it just feels stronger, like to know what I'm getting myself into to.
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
Originally posted by riopoopie:
im the guy that has the faniza flywheel on my car.
What's this Fananzia (faniza) flywheel? (even listed in your mods???) And it's only 8lbs? Bullsh!t... Never heard of that...
We're are talking about Fidanza's 11.5lb unit.
2000 SVT #674 - Check it out!
The guy who's working on my dead Zetec told me today that the stock flywheel is stamped sheet metal! Aluminum has got to be better than that.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Wow Paul you got some nice nature photographs on your website!
Don't know abou the whole stamped sheet metal thing.
-James
SVT with CE light mod and a camera mount.
Naughty Pictures
Why yes it is true, I am on my third engine.
I keep hearing these vague references to problems with aluminum flywheels. Pretty much every racer I know will run an aluminum flywheel, regardless of the cost, if the class rules allow it and one is available for the vehicle. I have never heard of a problem with an aluminim flywheel, other than burning of the friction surface caused by poor clutch usage.
Has anyone here ever had a problem with an aluminum flywheel?
FYI... I'm not being sarcastic, just curious.
John Coffey
johnc@betamotorsports.com
0
0
I don't know if this counts but,
I had the SHO Shop 8 pound unit on my sho,I know It's not a tour smile
Anyways, I never had a problem with durability. It did have a steel insert and starter ring. The engine did have a bit of a rough idle though. The clutch I used was the Hi Revs race duel diaphragm kevlar clutch, AKA lots of clutch chatter,hard launches and tire spin. I know that when I do the clutch on the svt I will go to a aluminum unit and a clutch with more manners for sure smile
Good luck on your decision.
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!!
It's a chronic disease.
ok deamon MY flywheel is 7 pounds (put it on the scale myself) and to whoever asked i havent had any time to run it on the track or dyno it yet but that will be in the near future. by the way deamon dont say that anything is bull untill you know what your talking about thanks eek
  • 98 Svt Toudor red/ Silver(Two tone)
    Midnight Blue and Black Carbon fibre Kit
  • SCA Cold Air Intake
  • Unorthodox Stage 1 Clutch
  • Fananzia Flywheel @ 8 lbs
  • Poly Engine Mount Inserts
  • Bosch Plat +4 Plugs
  • 8.5mm Magnacore Wires
  • 80/100 Watt Light conv.
  • Alpine 7864 SE Silver Head unit
  • Alpine GEQ 320 Digital Crossover linked to head unit via AI-Net
  • Phenix Gold M44 amp for highs and mids.
  • PPI PS2100 for JL12W6 flush mounted in rear spare tire hold.
  • Eclipse Componets all around.
Pardon me, I was not realizing the difference between a MTX flywheel and an ATX "flex plate". Still, it does seem kind of cheezy to have hollow gear teeth.
Page 2 of 2 1 2
