Posts: 22 |
Awesome work.  Those manual boost controllers tend to work oddly on externally gated turbos. Its a matter of how much it can bleed really. Any pics of your setup? I would love to see it. And thank you for putting your life out there to protect what we come to know as freedom. I commend you.
Posts: 5,810 |
check your private messages. The flasing red flag at the top of the screen. I'll send you my email address and if you want some pictures I'll email them back to you.
See My Mods
Posts: 60 |
wow that is a lot of HP good job i think that my car could accelerate that fast if i dropped it off a cliff..
95 contour SE
5 speed fun to drive but u already know that
JVC head unit
audiobahn 8002t
Infinity kappa 6x8's
Audiobahn Q's 12"s
loud very loud
Posts: 2,676 |
because your car would accelerate 9.8m/s^2 if you dropped it off a cliff. . .
Posts: 1,196 |
Originally posted by ssmumich00: because your car would accelerate 9.8m/s^2 if you dropped it off a cliff. . .
Doesn't that vary slightly depending on where you're at in the world?
2004 Evolution VIII cams-exhaust-tune
315whp 12.7@109
Posts: 495 |
You sure about using Iridiums? Most people on the Focus Forums are using copper. TurboTom custom makes his own plugs to fit since you can't get copper and colder more than one step for the zetec and at 400whp, he needs at least 4 steps colder. As for an ignition upgrade. Most people on the Focaljet recommend the J&S safeguard. It can do everything a MSD DIS2-4 can do but it can also monitor knock and retard timing when it senses knock/deto. Everybody who has one there swears buy it. They also make one for V6s now. Here's the link, if you don't already know. http://www.jandssafeguard.com/Have you ever thought about running water injection? Again those guys on the Focaljet who have it swear buy it. Might be able to run more power on 91 octane with the J&S and H20 injection than without. Good numbers.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 411 |
Originally posted by BStoneMega: Originally posted by ssmumich00: because your car would accelerate 9.8m/s^2 if you dropped it off a cliff. . .
Assuming a zero friction enviro- the acceleration of gravity is the same wherever you are on earth.
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 1,325 |
Originally posted by vudusvt: Originally posted by BStoneMega: Originally posted by ssmumich00: because your car would accelerate 9.8m/s^2 if you dropped it off a cliff. . .
Close but not quite - the force of gravity decreases with the square of the distance between the 2 objects F = G m1 * m2 / r^2. While relatively small, gavity would be less on the top of Everst compared to sea level. For the g force acceleration g= G m / r2 where r and m are the mass and radius of the earth. g has the value of 9.78039 x 10-1 m.s-2 at the equator and 9.83217 x 10-1 m.s-2 at the poles (since the earth is somewhat flattened at the poles). Diff would be bigger on everst
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 1,859 |
Originally posted by Seawulf: You sure about using Iridiums? Most people on the Focus Forums are using copper. TurboTom custom makes his own plugs to fit since you can't get copper and colder more than one step for the zetec and at 400whp, he needs at least 4 steps colder.
That safeguard sounds intresting, anyone else around here have experience with it. The only thing is I thought sytems that went through Knock sensors, were actualy seeing the results to late, as in retard the timing after the motor had already detonated and thus causing damage. I don't know, maybe its sensitvity is precise.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 411 |
Originally posted by ScottK: Close but not quite - the force of gravity decreases with the square of the distance between the 2 objects F = G m1 * m2 / r^2. While relatively small, gavity would be less on the top of Everst compared to sea level. For the g force acceleration g= G m / r2 where r and m are the mass and radius of the earth. g has the value of 9.78039 x 10-1 m.s-2 at the equator and 9.83217 x 10-1 m.s-2 at the poles (since the earth is somewhat flattened at the poles). Diff would be bigger on everst
C'mon Scott, this is Intro to Physics 100A- save your advanced, real-world calculations for Vectors/Statics 400!
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
