I am new to the board. And do not mean any disrespect, or offense by this question. I do not see why you belive that 388 is the max for the 57 trim. Perhaps max for its max effciency but max by no means. i mean step it up to a 1.2-1.3 bar, and increase the flow of your head and you are still able to kick up the power by a ample amount. Unless your motor just does not breathe well. How did you come up with teh conclusion that the 57trim was all "used up"? By a comp map? If so then there is alot more involved than a compressor map. There are turbine maps to be looked at as well as volume efficiency of the engine. I know for a fact that a 57trim can go way over 388whp. I have built many 4cyls that have a 7000rpm redline and made more than 450+whp @ 9.2 comp @ 18-20psi. Many folks over at hondatech have done it as well. Now its won't be the most effecient but it will still be up past 400whp. i would say that all the upper trim levels 57, 60, 60-1, and 62-1 (this one is a bit much), can make over 450whp. Hell in the honda community they do with 60-1's that turbonetics still can't fathom. again this is not a offensive post just some fyi that i have seen with my own eyes.
also other peoplr have as well. Look on vwwortex.com, honda-tech.com, etc.
on another note, if you want more power i would suggest to you a sc61 or its61... Its is a t350 turbine in a .63 a/r t3 housing, with a 61mm inducer compressor wheel with a 56trim, and can be configured with a t04e or s comp cover (i would definately suggest the e cover considering the space available). Now this turbo is supposed to only make 450whp... But i have produced over 620+whp on this turbo.
sorry for the long post, and congrats on the power achieved and very nice numbers for pumpgas, whats your compression?...
PS: what do you mean about the car ripping itself apart? does it feel unsafe at those levels? WHo has made the most power out of teh 2.5l? And how much is it?
Thanks again.
Off of PTE site. SC-34 is what they call a 57 trim. comp wheel overal diameter 56mm, Inducer size 2.230", Exducer - 2.950", turbine wheel - T31 also known as a stage 3. inducer - 2.559" , exducer -2.121" 69 trim. Max rating of 545 bhp... Now PTE is moderate when they list there turbos. Typically it isn't BHP is more like WHP.
this is a 1jz toyota engine i-6 2.5 liter, 22psi on a 57trim full t4. But just to show you that the 57trim doesn't run out of breathe.
And Warmonger is absolutely correct. Of course you were gonna lose lowend. But I garauntee you when you find your performance bottle neck (ie: reason why 388 is the max power of your 57 trim), you would rather have the extra umph uptop then downlow.
