Posts: 1,786 |
Originally posted by Tim: Hey now.. I thought you said you were going to shoehorn that big old' LS v8 of yours into a GL first ?
With all of these camaro-eating Contours out there now, we could stand to have one or two V8 grocery getters...
I did say that, didn't I?  Notice the "slight modifications" phrase.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 5,810 |
congratulations Chris!
I'm happy you finally made a beast 2.5L. I suppose you can begin working to keep all that power to the ground now.
warmonger
See My Mods
Posts: 5,810 |
I know he isn't using secondaries so why the drop in torque at the place where the secondaries normally open up? I thought with full controll over the timing it would enhance that portion of the graph? Maybe it is still the product of the manifold design having two efficient rpm ranges for air to flow well. If that is the case then having secondaries in or not is really not an issue since the actual manifold design with regard to tube length and diameter is the deciding factor. Probably the cams still have something to do with it too.
See My Mods
Learned patience the hard way
Posts: 2,454 |
Congrats Chris!!!! It's a ball having that much power on hand isn't it! Hats off to you sir (and Keith)
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 9,602 |
Originally posted by warmonger: I know he isn't using secondaries so why the drop in torque at the place where the secondaries normally open up?
But he is using the secondaries.
I keep telling him to pin them and set the IMRC point to 2000rpm or lower to remove the harsh jump and pressure loss from them opening and see what kind of graph it makes.
IMO it would generate boost sooner and it would definitely get rid of the drop in mid range power.
Boost pressure is a measurement of restriction. It is a major restriction running on only the primary ports then followed by a big pressure drop opening the even larger secondary ports.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,786 |
Originally posted by DemonSVT: Originally posted by warmonger: I know he isn't using secondaries so why the drop in torque at the place where the secondaries normally open up? I thought with full controll over the timing it would enhance that portion of the graph?
I keep telling him to pin them and set the IMRC point to 2000rpm or lower to remove the harsh jump and pressure loss from them opening and see what kind of graph it makes. IMO it would generate boost sooner and it would definitely get rid of the drop in mid range power.
Yes, that intake with the fancy secondaries is made for NA. There is meant to be a negative pressure in those runners for them to work optimally (relative to the outside air).
Ideally, a metal single-runner 3L upper would be best, with the 2.5L LIM matched and siamesed, and the heads tapered match on the ports. Leave the injectors pointed at the primary ports. The gas is going to get in there, no matter what
That could take you over the 400WHP mark.
Just my opinion.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
SuperChipFOR SALE
Posts: 2,676 |
hehe, Nice chris, I see you didn't waste anytime with the intercooler. . .
hmmmm, Chris are you running the larger TB and MAF as well, or just a larger MAF? I wonder what it would be like with a different intake setup (3L). . .I'm with Demon, w/o the secondaries, 400fwhp is attaiable. . .but 390 is fine with me.
Good to see that potential, thanks for posting the numbers. . .
Posts: 9,602 |
Originally posted by Chris Hightower: Ideally, a metal single-runner 3L upper would be best, with the 2.5L LIM matched and siamesed, and the heads tapered match on the ports.
Just my opinion.
Not necessarily.
The split port manifolds have a much high cfm flow ability and a much larger port area. That is a given.
With forced induction the less restriction the more power from the exact same setup. Advantage split port manifolds.
Since Chris is already at or just over the compressor's rated limit and doing it with less boost pressure I'd say his setup in very efficient. (I calculated 110-112% efficiency vs norm)
Switching to smaller intake ports might get him to see higher boost pressure (it's just a resistance measurement) but definitely will produce lower overall cfm flow and therefore less power.
Now the ST220 did come with an Aluminum oval port manifold that is supposedly hand portable. (i.e. no bends and you can accurately open up each port identical to the other)
If have not seen one of them personally nor could fathom a price estimate.
It does sound like an intriguing part though...
Now the larger plenum volume of the oval UIM can show benefits over a stock split port manifold on a NA engine. (3L especially)
However most people seem to forget EHing the split port UIM adds volume as well as max cfm flow ability. The latter of which it already has an advantage in.
For instance I gained roughly 18-19% port volume over my DH UIM. That is at or "more likely" just slightly beyond the limit of the split port UIM though.
Funny thing is the 3L is 16.5-18.2% (vs 2544/2499) larger in displacement. Who knew...
2000 SVT #674
Posts: 1,860 |
I pinned the secondaries and it sucked terribly. The turbo fell right on it's ass. It would take at least an hour of playing with timing to get back close to where I now and I don't know what that would do for daily driving. The secondaries are staying. Once the motor is fully broken in, I'll switch to synthetic, go iridium plugs and try again. Likely I'll get 399.8 or something. Right now I kept getting a slight ignition drop right at the peak and I tried 2 different plugs. I might have reached the top of the ignition system. I'm gapped at .025 on NGK TR6 right now.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 1,859 |
St-220 manifolds shipped new with the exchange rate will cost you about $1000, thats without gaskets or fuel rail etc.. Would be nice to see, but you could have a custom one fabbed up for that.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
