Posts: 31 |
Whats wrong with my tempgague? The sensor is replaced but it didn't help. When the car starts to warm up it usualy works ok. But then it suddenly goes to the AL part of NORMAL, stays there no matter how i drive. Then it suddenly dropps to the white zone.
Mark, Contour GL 2,0 ATX, -98
Posts: 2,725 |
Ignore the dumb thing, all Zetecs do it basically.
Posts: 750 |
are you sure you replaced the correct sensor ? there's two close next to each other. you need to replace the one facing DOWN, the one facing UP is for the PCM.
Tiv
Zippy Zetec on his last legs.
Posts: 1,262 |
Originally posted by HITMANinMI: Ignore the dumb thing, all Zetecs do it basically.
mine doesnt do it...and its older than his (not many tours are older than mine)
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 41 |
Which sensor did you replace? The Coolant temp sensor is located in the Top of the Thermostat housing it monitors the coolant temp. This sensor controls the cooling fans and the like. The temp sending unit is located in the same general area but well below the thermostat housing, this one controls the dash temp indicator.
____________________
96 GL Sport
2.0L Zetec ATX
Custom Focus Intake
MSD Blaster DIS Coil
Posts: 8,301 |
Originally posted by Stryker: Originally posted by HITMANinMI: Ignore the dumb thing, all Zetecs do it basically.
Same here. My gauge has never went past the halfway mark. Its is pretty common for the gauge to show a lot hotter on Zetecs, though.
-Ken V.
psycho_bass@hotmail.com
Posts: 1,262 |
Originally posted by CRZYDRVR: Originally posted by Stryker: Originally posted by HITMANinMI: Ignore the dumb thing, all Zetecs do it basically.
well, mine is always past the halfway mark, but never acted crazy, its always pretty much stayed in one spot....between a-l on the gauge until recently. i got my IAC valve and TStat replaced and nopw it sits right about in the middle unless i drive er hard!
Regards, Cole.
Posts: 31 |
Thanx for all the advise and information. I didn't change it myself, so i'm not sure which one was replaced, maybe both. Someone told i must change the gague or maybe even all the gagues which seems crazy.
Posts: 31 |
I now brought it to another place and they changed the sensor the other shop should have changed and the temp gague works like it should  I am very happy becouse it wasn't even expencive. The other shop was quite embarrased when i told them.
