Page 4 of 4 1 2 3 4
They are suppose to have the coating but don't worry about it. I asked one of the intake engineers at Ford and he said that the caoting is suppose to prevent the build-up that causes the throttle to stick closed. Do you guys realize that these same screws you are talking about smoothing are in the secondary runner butterflys as well. Think about it, since the runners are smaller than the t'body and the screws are the same, they are blocking a larger percentage of the total area. So theoretically there would be even more advantage to cleaning up the secondary butterflys.
Dave T.
'98.5 Silver Frost E1
#4596 of 6535
Koni's
Fog Light Mod
Motor Mount insert
I'm guess there is a special tool, bit to make countersinks in the plate? Interesting thought on the secondary butterflies, that would probably be a lot of work but probably well worth it, what are they like 33mm or something so yeah that is a way higher percentage.
The secondaries? Not in my car :rolleyes: laugh
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
V
V
can this be down to the 65mm mustang throttle body as well? if so how much would ya charge to do this for me?
im not driving too fast, im flying too low...
Could be done. Same charges as the rest of them...
Brad Noon
'99 SE MTX
Originally posted by hunymobile:
Ok, where's the guy that always comes in with his crap and says that won't do anything??? hahahaha
actually i think is a really good idea. i doubt you will get more then 1-2 hp, but i might help to smooth things out. i don't naysay everything... laugh
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
Finally got around to taking the TB off my Mondeo yesterday.... I've got the bar running across BOTH sides of the butterfly (and it's really thick) and I've also got the Teflon coating on the engine side of the butterfly. The coating looks to be next to useless, my car has done less tha 4000km and the coating was already chipped away at the edges of the butterfly and had a coating of oil gunge on it already too.
Measured the diameter of the butterfly to be 54mm- is that what you guys with the standard Duratecs have got? How much bigger is the SVT version?
David
Mondeo ST24 Information Site
yr 2000 silver Mondeo ST24 V6 MTX
mods: Custom alloy air intake using K&N RC-3250 air filter; Koni Sports shocks; rear 20mm Selbys sway bar; THF; EBC Greenstuff front pads, custom exhaust.
Originally posted by Sandman333:
Where did you get the screws for that?
Home Depot or similar: They are a metric thread, flat head, phillips machine screw. I think they are 4mm, but I would take one of your originals with to match up with. The length will probably be too long, but you'll be filing that off smooth with the shaft anyway.
Scott
SVT Contour is 60mm. Mustang TBs are 65mm stock and 70+ aftermarket.
Brad Noon
'99 SE MTX
Page 4 of 4 1 2 3 4
