Posts: 3,248 |
Hey Brad, what would you charge to tweak an SVT T-body (if your interested)? I just dont have all the tools.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 3,562 |
Originally posted by Dan Nixon: Hey Brad, what would you charge to tweak an SVT T-body (if your interested)? I just dont have all the tools. $35 exchange, $90 core refundable unless I recieve your TB up front. Please remove your TPS before shipping cores.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Administrator
Administrator
Posts: 5,037 |
I wonder if it would help airflow if some JB Weld or something was used to fill the turbulaence-causing lip on the butterfly where it is held on by the shaft? THat stuff can be put on, and then shaped to look/act great.
Administrator
Administrator
Posts: 702 |
Brad, I've got an SVT TB sitting here waiting to be installed (for a while now). Should I ship it to the address on your web page? I'd do it myself, but I don't have the time or garage space anymore - darn apartment living!  -Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 3,248 |
Brad, that sounds good. Do you have an SVT T-body already to modify while awaiting my core return? Whats your e-mail again?
Posts: 3,562 |
bnmotorsports@msn.com Yes, I have one ready to go... the one that was on my car. I've taken it off and cleaned it up for sale.
Lance, I can do that for you. Addy on the web "order" page is current.
Posts: 4,899 |
Brad -- I have a non-SVT...can you do it to that one?
And it is basically $35 if I send you my TB, right?
Posts: 1,847 |
Originally posted by tw0wheelin: Who said anything about beer??
Today I took the TB back out and took another 1/16" inch of the back side of the shaft. (I used a file and then finished with fine emery cloth. I also replaced the scews with countersunk flat heads and added countersinks to the butterfly plate. Works even better!
Countersunk screws are completely flat!!Where did you get the screws for that?
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
Posts: 265 |
Hey Brad, How much to optimize a 70mm unit?  Da(m)n Beggs 99 Cougar V6, phast
Posts: 3,562 |
Originally posted by TheContourGuy: Brad -- I have a non-SVT...can you do it to that one?
And it is basically $35 if I send you my TB, right? Yes, but it will still be treated as a core exchange, so remove your TB as I already have an SE TB done and ready to send out. Da(m)n, yes the 70 can be optimized too... :rolleyes: I would think that reduction in turbulence would actually help the larger ones more as to help keep air speed up. Those screws can be had at just about any home repair or hardware store. If you do your own, remove the bar from the TB and take it with you to ensure proper threads. Easy as pie... Just have to have the tools.
