#968568 06/01/04 04:51 PM
H
H
anyone know how i can test a window switch to see which connector tab operates each "arrow". i assume there's a tab for illumination and power,etc. and i'd guess one for the up function and one for the down function. is there a way to isolate which tab works the up and which works the down?
i've never actually seen the back of one of those switches, but being an electronic engineer, i can tell you...
if you take a meter, and press it on one of the tabs, take the other and pick a random tab. test for continuity. if you have no resistance, then those are the two tabs for the light. if not, press the buttons and find out wich tabs are for what. just process of elimination. like i said though, i've never been inside the door panel, i just know how to test switches(as well as many other things). good luck!
96 contour gl columbus ohio
H
H
oh i got what your saying. i did that with my rocker switches that i installed. i forget what it is but the reading will be 0 or 1. i'll try that
You look for resistance, the master switch, looks more PITA... other, should be easy
(using an Ohm Meter)
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
