Posts: 8,143 |
and I bet you either rub like a [censored], had to roll your fenders, or have rubberband tires
and actually I have 17x7 wheels and I can tell you that any wider will rub.
so DUDE, you're still wrong.
Posts: 260 |
2k silver svt #1721
Ignorance breeds stupidity..
Posts: 548 |
i know my 17x7 would rub with 4 people in the car when i hit a soft hole on the highway, it ws always the inside corner on the back tires
never had a problem with them when it was just me driving
98 contour gl, v6 auto
01 explorer sport v6 auto
2001gtp AT gmail DOT com
Posts: 260 |
All you need to do to fix that Putz is trim the inside of your fender where it meets the bumper, takes 5 minutes with the wheel off. Touch it up with a bit of paint just to make sure rust does not set in.
2k silver svt #1721
Posts: 1,785 |
I have 18" and I don't rub. 18" X 7" and I didn't have to trim the bumper because I don't have an SVT. 225/40/18 is the tire size.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 8,143 |
Originally posted by unknown: All you need to do to fix that Putz is trim the inside of your fender where it meets the bumper, takes 5 minutes with the wheel off. Touch it up with a bit of paint just to make sure rust does not set in.
which falls into the category of modification but thanks for your time ![](/ubbthreads/images/graemlins/troutslap.gif)
if you REALLY wanna get technical...whether you rub or not depends on wheel offset and tire size which pretty much makes it hit or miss when installing 18"/19" wheels
soooo the best way to avoid any of that is to buy yourself a set of 17x7 wheels with a 215/45/17 tire which requires absolutely no modifying at all...not even "5 minutes" worth.
Posts: 548 |
my 17x7 was a 215 17 45
but how often do you put 4 full grown people and 100 lbs of subs, and fishing gear in the trunk
Posts: 72 |
Originally posted by unknown: Dude, I own 19s, I think I would know if there were any modifications needed. Do you own 19s? I doubt it considering the bad information you are giving.
yeah i am definately running 19's with NO MODS. in fact i may have made it even more interesting with the konis and eibachs. still no modding needed. 19 by 8 is a little bigger than your guaranteed 17 by 7's.
PERSONAL MECHANIC- BUCKEYESVT
02 3 Liter
SVT heads/Cams
3 liter UIM/LIM
24lb injectors
Diamond white pearl
Koni's/Eibach's
19in Axis NE-O
Pioneer AVH-p6500 dvd
15% Tint
NO ENGINE CODES...
AND NO I DIDN'T DISCONNECT THE LIGHT...LOL
Posts: 72 |
all the time.
02 3 Liter
SVT heads/Cams
3 liter UIM/LIM
24lb injectors
Diamond white pearl
Koni's/Eibach's
19in Axis NE-O
15% Tint
NO ENGINE CODES...
Posts: 260 |
Originally posted by ZetecNinja: Originally posted by unknown: All you need to do to fix that Putz is trim the inside of your fender where it meets the bumper, takes 5 minutes with the wheel off. Touch it up with a bit of paint just to make sure rust does not set in.
We are talking about a solution to HIS problem w/4 people in the car and HIS 17x7s, not my 19s.
I'll say it again, ignorance is bliss.
2k silver svt #1721
