Posts: 8,143 |
and I bet you either rub like a [censored], had to roll your fenders, or have rubberband tires
and actually I have 17x7 wheels and I can tell you that any wider will rub.
so DUDE, you're still wrong.
Posts: 260 |
2k silver svt #1721
Ignorance breeds stupidity..
Posts: 548 |
i know my 17x7 would rub with 4 people in the car when i hit a soft hole on the highway, it ws always the inside corner on the back tires
never had a problem with them when it was just me driving
98 contour gl, v6 auto
01 explorer sport v6 auto
2001gtp AT gmail DOT com
Posts: 260 |
All you need to do to fix that Putz is trim the inside of your fender where it meets the bumper, takes 5 minutes with the wheel off. Touch it up with a bit of paint just to make sure rust does not set in.
2k silver svt #1721
Posts: 1,785 |
I have 18" and I don't rub. 18" X 7" and I didn't have to trim the bumper because I don't have an SVT. 225/40/18 is the tire size.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 8,143 |
Originally posted by unknown: All you need to do to fix that Putz is trim the inside of your fender where it meets the bumper, takes 5 minutes with the wheel off. Touch it up with a bit of paint just to make sure rust does not set in.
which falls into the category of modification but thanks for your time
if you REALLY wanna get technical...whether you rub or not depends on wheel offset and tire size which pretty much makes it hit or miss when installing 18"/19" wheels
soooo the best way to avoid any of that is to buy yourself a set of 17x7 wheels with a 215/45/17 tire which requires absolutely no modifying at all...not even "5 minutes" worth.
Posts: 548 |
my 17x7 was a 215 17 45
but how often do you put 4 full grown people and 100 lbs of subs, and fishing gear in the trunk
Posts: 72 |
Originally posted by unknown: Dude, I own 19s, I think I would know if there were any modifications needed. Do you own 19s? I doubt it considering the bad information you are giving.
yeah i am definately running 19's with NO MODS. in fact i may have made it even more interesting with the konis and eibachs. still no modding needed. 19 by 8 is a little bigger than your guaranteed 17 by 7's.
PERSONAL MECHANIC- BUCKEYESVT
02 3 Liter
SVT heads/Cams
3 liter UIM/LIM
24lb injectors
Diamond white pearl
Koni's/Eibach's
19in Axis NE-O
Pioneer AVH-p6500 dvd
15% Tint
NO ENGINE CODES...
AND NO I DIDN'T DISCONNECT THE LIGHT...LOL
Posts: 72 |
all the time.
02 3 Liter
SVT heads/Cams
3 liter UIM/LIM
24lb injectors
Diamond white pearl
Koni's/Eibach's
19in Axis NE-O
15% Tint
NO ENGINE CODES...
Posts: 260 |
Originally posted by ZetecNinja: Originally posted by unknown: All you need to do to fix that Putz is trim the inside of your fender where it meets the bumper, takes 5 minutes with the wheel off. Touch it up with a bit of paint just to make sure rust does not set in.
We are talking about a solution to HIS problem w/4 people in the car and HIS 17x7s, not my 19s.
I'll say it again, ignorance is bliss.
2k silver svt #1721
