Page 6 of 6 1 2 3 4 5 6
#96653 05/25/01 07:23 PM
N
N
Originally posted by Silversvt:
Ok, I think I need to reel you engineers back in the realm of cars laugh
Sorry for getting off topic laugh
...3rd gear. Don't you think that when the stock rubber on the SE rotates at that speed, its contact patch diminishes because of centrifugal force acting on the tire, whereas the wide rubber mounted to my 18's still puts its "4in x 6in" of rubber to the asphalt?
When you are going through 3rd gear during this acceleration your entire contact patch is under pure rolling (i.e. no slip is occuring). It's therefore actually ideal to have as small of a contact patch as possible (before slipping begins to occur again) to minimize your rolling resistance.
Factor in the aero drag because of the width and you see why that SE was able to pass me...
Aerodynamic drag caused by the tread or width of the tire accounts for only a small portion of the overall rolling resistance of the tire. This would not have a significant factor in your performance here. The texts I've seen always neglect this drag when speaking of rolling resistance. Unless you're talking about the added drag from your 18's making your car sit up higher...is that what you're talking about?
ND SVT
2000 SVT (Black/Midnight Blue)
#96654 05/25/01 11:59 PM
Hey pascal, why don't you and jeff swap rims, then take another run at it. Just so we can drop the insanity about 18" wheels dropping 30hp. smile
Personally, I think it's engine related. I'll bet a dyno would prove this.
#96655 05/29/01 05:00 PM
In addition to plugs & T.Body cleaning, may want to remove & clean your upper intake and clean your lower intake/ secondaries in place. They can get pretty gunked up from the EGR crap. While doing that, check to see that your intake manifolds are "port matched", it has been mentioned that this can be off a little. Consider fuel flow as well, injector cleaning and new fuel filter. Make sure your air filter is clean. Just a bit of TLC & youll be back in business.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
