#966227 05/28/04 05:57 PM
well i was wiring up the diamonds the other day and when i turned on the hu, the amp didnt cut on. so i checked fuses and both were blown. so i put new ones in and turned on hu and the amp started smoking. im pretty sure it was because i had a loose ground. but i thought the fuses would have blown again before that would have happened. any way the green light on my amp still cuts on but i cant get any sound from it. i opened it up and part of the board looks burnt and two of the wires have come lose. i tried pushing the wires back in and tried it again but still no sound. can this be repaired or should i just throw it away
by the way the amp is a jbl bp600.1
blue 95 se MTX alpine 9805 2 diamond 12" cm3's tuned to 38 hz 4 pioneer 3-ways(POS) jbl bp1200.1 pimpin hoes, like the river flows..... constantly!
#966228 05/28/04 07:09 PM
It can't be sent in for warranty?
Tempe
#966229 05/29/04 06:02 PM
i dont think it would be covered by warranty. as soon as they opened it up they would know it was failure of proper installation
#966230 05/29/04 07:29 PM
i know when i blow a fuse, i will try to figure out why it blew before tossing another in there....
i'd take it to a local shop and have them run an estimate on it....
#966231 05/30/04 04:00 PM
H
H
The fuses probably went as soon as you connected the main battery cable. Sounds like you have the positive and negative cables reversed. I did that last time I worked on my car Popped the fuse, but thanksfully that was all. Checked everything out and realised my mistake...
I can't figure out why the new fuse you put in didn't just pop though before burning up your amplifier
2003 Ford Focus ZX3 "Tarmac" http://www.cardomain.com/ride/2352003
Moderated by  dnewma04_dup1
