Page 1 of 3 1 2 3
Check this out guys:
-SZ02'-159 hp on the DynoJet with true duals, gutted pre-cats, drop-in K&N and 30K on the car.
-May 03' netted me 168 hp on another DynoJet with the same mods but 42K on the clock.
-SZ04' I pulled 171.something hp on the Mustang Dyno and my only mod was a BAT pipe and 9" K&N filter. The car now has 49.5K on the clock and with the correction my car has 188 hp now Finally the car is putting out a respectable number and on this dyno it shows how good/bad your clutch is and guess what, mine is GREAT, big surprise
that's a LOT of variation, wow. I'd probably find the middle ground in there, but if I were you I'd go by 188....
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
I really broke my car in easy, like not going over 3500K for the first 2K of driving, so I guess it really took sometime for it (the motor) to break in. I also added a bottle of additive to the oil change for the first 30K of driving, like (3) bottles worth, so that too may have played a factor into why it took so long. All I know is that on the Mustang Dyno, where the hp #'s are always lower, I pulled the best hp # I've ever pulled
YEAY BRICK!!!
j/k
Congrats on the major improvements..
Ray
CEG road warrior
CEG road warrior
Man Roger, you were glowing after your runs on the dyno....now all you have to do is push the pedal down more to use the power.....J/K
171 aint half bad at all. What correction factor bumped you up to 188?
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
The guys at the dyno said its about a 10-15% correction factor to what a dynojet would read, so they were just adding 10% to everyones numbers.
That's real accurate...
It's 171 on a Mustang dyno. That's it.
LOL...can I add 17hp to my last dyno, too?
Either way, Roger, I'm glad your car keep gaining more hp without modding it. That's awesome!
I'm a little surprised to see this post Demon, not what I expected from you at all. Most of us, including myself, have spent time on a DynoJet and its true the Mustang Dyno does infact dyno a bit lower due to how its set up, so thats why we ALL got the correction, 278 hp for Stazi, 254 for Scott Biggers turbo'd CSVT, 200 for a straight 3.0L hybrid and my 188 hp corrected. I don't think any of us are "pumping up our hp #'s", were just realizing our gains had we been on the dyno we're used to, thats all.
Page 1 of 3 1 2 3
Moderated by  mbb41_dup1
