Page 16 of 17 1 2 14 15 16 17
I asked for:
33mm Primary
34.3mm Secondary
67mm TB Inlet
....aka- the limit the split port UIM can be EH'd to.
I only hope that's what I get
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
Originally posted by Swazo:
I asked for:
33mm Primary
34.3mm Secondary
67mm TB Inlet
Looks like they came back around 31mm/33mm, they may be a little more because the opening are not perfectly round. If you port match you will open them up a little more but not sure if you will get 33mm/34mm. Pete did say they were very close to the gasket openings though. Also the TB inlets did come back at >69mm very close to 70mm in all three UIM's we got back.
Scott
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
Correction...checked my numbers and the TB openings were all 69mm, not 70mm.
Scott
Derk-xB Offline OP
I've been moving , but here's a quick update from Rick:
Derek, I finished airflow on Friday. The SVT intake airflow avg. before
is 266.3 cfm. After Extrude hone processing the avg. airflow is 288.9.
The stock intake airflow avg. before is 251.7 after the airflow avg. is
285.3. We used a SVT lower intake for airflow
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
Very good...thanks Derek.
Going from non-SVT to SVT UIM is a gain of about 15 CFU/m (and worth about 5 HP). Going from SVT to "extra Hone" is a gain of about 22 CFU/m (even in the setting of the LIM restriction) so I would then "guess" this should worth about 7 HP (at least in the setting of the SVT honed intake ports /hotter cams). Not bad...
1999 Amazon Green SVT Contour (#554/2760) "People demand freedom of speech as a compensation for the freedom of thought which they seldom use." -Soren Kierkegaard (as posted by Jato)
Were the butterflies in place on the SVT LIM?
W
W
Hot damn!! Chris justed called me. My UIM is going out today to Jet Hot. Things are moving right along--how refreshing!! Thanks to all involved. Too bad 1BADTOUR didn't go the same route.
WA 2 TUFF SVT 2000 Tropic Green SVT Born 1/28/2000-1975 out of 2150-only 207 made. Some new pics
D'oh.......I had my package returned. I put it in the night drop off/self shipping deal the night before I left on business. It looks like I'll be paying full price.....I need to get this done reguardless
#965762 08/09/04 11:37 PM
Derk-xB Offline OP
Well, I hope I'm not speaking too soon, but this group buy went rather well. For that, I'm very happy.
I'd like to thank Massiv for all his help here and on the Cougar site; SVT PETE, and scottd60 for their help aquiring info from EH and taking measurements; thanks to everyone who chipped in and chimed in with info, too.
I hope everyone winds up happy with this GB, too.
-Derek
#965763 08/11/04 05:23 PM
Derk-xB Offline OP
FWIW, my ports came back as:
TB - 68mm
Primary - 32
Secondary - 34
Sure, I'm measuring with a ruler so the numbers are limited in their accuracy, but they're relatively consistent. I'd say at most there's a .5mm discrepency between the ports, but again, they're not 100% round. I'm not going to bother port matching, as I doubt my rounding capabilities are worth the effort.
Moderated by  1314_dup1
