Just for some clarification here. The focus mtx75 box itself will mate onto the 2.5L contour bellhousing which will mate onto the 3.0L with slight or little modification?
Ex-cat cams dealer. Today we do motor mounts.. Tommorow. Intake manifolds
Input shafts are diffrent. just found out. I was talking about using the 2.5L bellhousing on the 2.0L gear box. But it wont work because of input shaft diffrences.
I was thinking about moving a 2.5L that I have in a wrecked car over to my manual 2.0L, does that mean that these would have different input shafts as do your 3.0L and 2.0L manual transaxle? Or would I just need a different bellhousing for my situation?
Originally posted by Alex532: I was thinking about moving a 2.5L that I have in a wrecked car over to my manual 2.0L, does that mean that these would have different input shafts as do your 3.0L and 2.0L manual transaxle? Or would I just need a different bellhousing for my situation?
You would need the majority of the front end of the car.
Almost everything is different. (subframe, axles, harnesses, you name it, etc)
2000 SVT #674
13.47 @ 102 - All Motor!
