#962350 05/24/04 09:23 PM
00 with 63.6k 2.5 (ex-rental)
when shifting up at about 35-42mph (depending on how hard you are on the accel) it kinda bumps almost like its vibrating or not going into gear correctly, almost like you were rubbing a peice of rubber on the floor and it would vibrate up and down kinda noise you can feel it in the car, but its not terrible, but it's cropped up recently
it's hard to explain but that's the best i can do
will a flush fix this or make it worse ya think?
jesus I hope this means the trans is on it's way out ver very soon, or it's nothing ...
i could only hope
hard shifts randomly
TYIA
#962351 05/25/04 02:32 PM
At 63k on an ex-rental I would probably not do a flush. My cd4e first started shifting funky after a flush at 60k. I am the second owner so I don't think that fluid had ever been changed before. That flush, among other things, probably contributed to the problem I'm having now.
IMHO, you should probably have it drained and filled a few times. Have it done once, drive it for a week or so....then have it done again.....and again if you want.Good luck.
98 Mystique LS DOB 06/97
