Fcuk Fototime
FotoTime is having problems sending your browser cookies.
What types of cookies your browser is accepting
Your browser is NOT accepting session cookies
Your browser is NOT accepting stored cookies
What we use cookies for
FotoTime values people privacy. Although cookies are required to use FotoTime, we do not use cookies to store personal information about you. We use cookies for:
We use a cookie as a key to each user session to differentiate logged in users because IP addresses are not unique.
We use a cookie to direct our load balancing equipment to always send you back to the server you logged in to.
We use a cookie which stores which upload method you use (browser or ActiveX) so that when you upload again, it remembers your preference.
The first thing to check
If you believe you have cookies configured properly as described below, and they still are not working, be sure to check that the time is set correctly on your PC. An incorrect clock setting can cause cookies to fail.
We show your PC clock setting as: Saturday, May 22, 2004 16:24
How to enable cookies in your browser
Internet Explorer 6.x
From "Tools" in browser menu, select "Internet Options"
Click "Privacy" tab
Confirm that privacy setting is not set to "Block All Cookies"
At the bottom of the "Privacy" tab, click the "Edit" button
In the "Address of Web Site" field, enter
www.fototime.com Hit the "Allow" button
Hit Ok to close the "Per Site Privacy Actions" window
Hit Ok to close the "Internet Options" window
Internet Explorer 5.x
Click "Security" tab
Click "Internet" icon
Click "Custom Level" button
Scroll to "Cookies"
Select "Enable" for "Allow cookies that are stored on your computer"
Select "Enable" for "Allow per-session cookies (not stored)"
Scroll to "Java"
Select "Enable" Java permissions at low, medium, or high safety
Click "OK"
Internet Explorer 4.x
From "View" in browser menu, select "Internet Options"
Click on the "Security" tab
Click on "Advanced"
Check "Enable Java JIT compiler"
Click "OK"
For cookies:
From "View" in browser menu, select "Options"
Click the "Advanced" tab
Scroll down to "cookies" (under "security")
Check "Always accept cookies"
Click "OK"
Netscape Communicator 4.x
From "Edit" menu on browser menu bar, select "Preferences"
Click "Advanced" in menu
Check off "Accept all cookies"
Check off "Enable JavaScript"
Click "OK"
none of that crap works. in pain. pissed off. on drugs.
