#95933 05/15/01 11:56 AM
As an interesting project to do with my father, I was thinking of modifying my SVT's hood for forced air. My father was suggesting a NACA air duct, but I don't know where there would be enough clearance under the hood. I don't want to have to resort to oversized hood scoops either. Does anyone have any ideas, or has anyone actually done this?
Mike Roberts
98.5 E1 SVT Contour
B&M Short Shifter w/ Momo Race Air Leather shift knob
K&N air filter in modified (hacksawed) airbox
Alpine 60WX4 CD deck w/ 3-way Pioneer Speakers
MTX 280 watt amp powering a single Kenwood 10" subwoofer
#95934 05/15/01 01:00 PM
Administrator
Administrator
There is enough clearence, and I have a NACA scoop, but I have decided to put it in the fender. That way I don't have to worry about mating surfaces and it gives more room.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#95935 05/15/01 02:35 PM
Do you have pictures? and how did you arrange everything?
Mike Roberts
98.5 E1 SVT Contour
#95936 05/15/01 04:57 PM
Look at Mr.Fancy pants, cutting up the Contour just because he has a LS8 to drive... :rolleyes: Pics please smile
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#95937 05/15/01 11:07 PM
Administrator
Administrator
Here is a pic of the installed position if I was going to put it on the hood.
And, YES, it will be cut smile
I don't have any pictures of it where it might go, on the fender. Just imagine it looking at the front, in the 1:30 position. (45 degrees to the right.)
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#95938 05/16/01 01:46 AM
OK .. I'm not an aerodynamicist (sp) just a 'boomer with a long memory. Another possible solution is to build an airbox behind the air dam and feed it from the fog lights. Then run a duct from the box to the MAF sensor ... similar to some 60's Trans Am cars.
Another possibility is a reversed hood scoop drawing air from the base of the windshield ala the late 60's early 70's 'cowl induction' set-up from GM.
Either way it would be necessary to figure out how to keep water out (or provide a drain) and it probably would be best to put one of those bypass valves in-line just in case.
#95939 05/16/01 02:51 AM
This is what we need... Maybe not the same looking scoops, but the setup is fantastic. I had sent this company an email a while ago with no response, so I called them today.. I had to leave a message. I wonder if they are going to call me. Please, if you are interested in a ram air hood, these are the guys you want to speak to. I have had products from them in the past, and it is high quality. Give them a call at 1-800-488-6057 or send an email http://www.cervinis.com/form.html
and tell them we would like a hood fabricated for Contour.org.
www.cervinis.com
1998.5 SVT
#95940 05/16/01 06:46 PM
I would like to get one if the price was right adn so was the look.
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
