Page 2 of 2 1 2
Originally posted by MiStEGRYM:
And Brad, I thought that you sent your PCM out after I did mine?? IIRC, your closet was still supercharged at the time I was just getting my car on the road.
That's what I thought too. First I thought just the SE's were that way, but Bob's wasn't... hummmmmm I know I had my tach on correctly as I had my 5" monster tach installed just before the SZ meet, but took it off as it read the same (I thought the stock tach was slow, is was, but not as slow as I thought).
confused
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
W
W
hmm, I have to talk to Trevor anyways, I will run this by him when i call.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
W
W
The Superchip mystery is being looked into as we speak.
-Mark
GTExtreme1@aol.com
Administrator
Administrator
I bet the limiter is more a function of the PIP (profile ignition pickup) than the EEC now, so changing the value in the computer probably doesn't do anything. Car's built sometime in 98 and after seem to not have the rev limiter removed with a chip. My theory, could be wrong.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
-Lance
That was my point though, that the regular chip I had ran to 7500 and the one from Vortech didn't... Mine's a 99...
Brad Noon
'99 SE MTX
W
W
I have an early 98 and I could run up to 7100 without a chip and now I can run up to 7500 with the chip.
-Mark
GTExtreme1@aol.com
F
F
Mine revs up to 7250 indicated on the tach. I would think this is actually 7500 but the tach just hasn't had time to respond. It is still not right, but running much much better. It feels like I have gained maybe 25 hp over stock. I know that is not good, but It doesn't stumble at 4000 rpm anymore.
I have called vortech many times, and the few times I actually talk to somebody, nothing they suggest really helps.
I hooked it up to a scanner the other day, and one of the banks is running richer than the other. Not sure what that means.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
W
W
Simon I just sent ya a private message.
-Mark
GTExtreme1@aol.com
You should hook a diagnostic analyzer up and see what the computer sees for rpm. I've noticed that my 00 SVT's tach is "lazy" above 6000 rpm.
The cutoff is 7096 rpm (Ignition/soft limit at 7000rpm) per computer's readings and the tach is maybe at 6900...
2000 SVT #674 - Check it out!
W
W
my rpm ranges came straight from dynomameter which was reading the same as my tach inside... the E1's might be off a bit, but I am not sure about.
-Mark
GTExtreme1@aol.com
Page 2 of 2 1 2
