Posts: 212 |
can I get one and do they lenthen the runners to make more torque?
98 silver frost SVT custom built intake, offroad y-pipe,mystery mod,remote optimizer,short shifter,zex nitrous, lots of stereo, 17 konigs
with paradas.(bent) TOTALED do to freak electrical fire?(that started at a wireing harness ford neglected to tell me should have been recalled as they did with the 95se) I miss this car.
NEW PROFFESSION AS A TROLL.
new car. 2000 dodge dakota 4.7l v8. custombuilt intake, custom exhaust, kennebell pcm, and electric fan conversion, 180 stat, 3.55 pegleg, my old stereo system, 17x7 billets and 255-50 nitto 450 tires. next drop and traction adders. g-tech 14.5
in search of 95 se fivespeed to hang contourparts on.
Posts: 1,149 |
Maybe on a carbureted model.. But unless you are running a throttle body injected engine.. A spacer won't do alot for you. Dom
Posts: 618 |
Originally posted by Cardoctor: Maybe on a carbureted model.. But unless you are running a throttle body injected engine.. A spacer won't do alot for you.
Dom  Yeah, but what about spacers between the upper and lower intake?
GOD BLESS AMERICA!!!
Ted tdavidk76@hotmail.com '95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX. Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods. Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
Posts: 2,708 |
Originally posted by tdavidk: Yeah, but what about spacers between the upper and lower intake? How about a cut out in the hood to allow such a modification? you don't have enough room for an intake spacer... not unless you like dents.. -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Administrator
Administrator
Posts: 4,527 |
just slam the hood really hard when you're done  actually, if you can get one that will fit, something like a phenolic resin spacer between the upper and lower intake manifolds may help power a bit, due to less heat transfer into the upper intake manifold. But, on the dual plenum, tuned length dual runner intake like the duratech has, one would really have to study the resonance effects of changing runner length to have any guess of what a spacer may do power wise. I'm not saying it couldn't be done, or it definately wouldn't be useful, just that it takes more knowledge than I have to tell if it is even worth considering (that and you need a "power bulge" in your hood to accomodate it :D)
It's all about balance.
bcphillips@peoplepc.com
Posts: 618 |
Originally posted by Rara: [QB]just slam the hood really hard when you're done  QB] LOL!!!!! Ok, so I didn't think about clearance restrictions!
Posts: 1,682 |
Originally posted by Rara: just slam the hood really hard when you're done
actually, if you can get one that will fit, something like a phenolic resin spacer between the upper and lower intake manifolds may help power a bit, due to less heat transfer into the upper intake manifold. But, on the dual plenum, tuned length dual runner intake like the duratech has, one would really have to study the resonance effects of changing runner length to have any guess of what a spacer may do power wise. I'm not saying it couldn't be done, or it definately wouldn't be useful, just that it takes more knowledge than I have to tell if it is even worth considering (that and you need a "power bulge" in your hood to accomodate it :D)well said. and you claim you landed your job by chance...
Posts: 212 |
I figured that was the case but remember some mustang guy saying somthing about it. appreciate the help though
Posts: 1,149 |
I didn't think I had to go that far... lol Thanks Rara..
Administrator
Administrator
Posts: 4,527 |
hey I'm an engineer, I'm required to make simple things as complicated as possible and confuse as many people as possible along the way. So if anybody that isn't an engineer and is still following what I am saying, let me know and I'll be sure to fix it
