Posts: 294 |
my subs require a subsonic filter when used in a ported box can someone recommend a good cheap one i remember seeing some on PE but i cant find em anymore thanks
blue 95 se MTX
alpine 9805
2 diamond 12" cm3's tuned to 38 hz
4 pioneer 3-ways(POS)
jbl bp1200.1
pimpin hoes, like the river flows..... constantly!
Posts: 4,639 |
r u referring to the fmod crossover simulators. i think they go down to 20 or 30hz high pass. should be able to find them on pe
Hugo AIM:omegazodiac
Posts: 294 |
well i mean the spec sheet says high pass ("subsonic") filters must be used with non-sealed applications to prevent over over-excursion at frequencies below port tuning. i am going ported and the recommended tuning frequency is 38.
so any suggestions on the filter??
blue 95 se MTX
alpine 9805
jbl bp1200.1
Posts: 294 |
can no one recommend one?
blue 95 se MTX
alpine 9805
jbl bp1200.1
Posts: 7,392 |
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 294 |
but that one is 20 hz, wouldnt i need one that is 38 hz?
blue 95 se MTX
alpine 9805
jbl bp1200.1
Posts: 7,392 |
Originally posted by contouranado: but that one is 20 hz, wouldnt i need one that is 38 hz?
nope. the tuning freq. is simply where the sub will begin to roll off. you'll still want it to play down to 20 Hz.
.....______
___|______\_____
|/-\_________/-\_|
Posts: 294 |
that link comes with two filters. im using a a mono amp and two subs, will i need to use both of those or just one?
blue 95 se MTX
alpine 9805
jbl bp1200.1
Posts: 89 |
I've ran the 30 for over two years. For a while I took it out. I notice no audible difference in sound. The setup is a RF 800a4, RE SE 12, and a 2.25 cube box tuned to 35hz with 24" port area....
Tempe
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
You won't notice a different but the speaker will play differently between the 20 and the 30..Either one you could go with and will be safe.
Or sell your JBL and get a matching Diamond D5 amp for your CM3's with a Subsonic built in
