Posts: 65 |
Merlin,
Was there any problems with your cars computer when you installed the off road y pipe without the cat or was it not a problem.
Just wondering if the check engine light came on or computer started freaking out
Thanks Brian
2000 SVT Green KKM True Rev Pioneer 6200 Head Unit Rockford 800a2/600a4 amps Infinity kappa's/Polk 12" dx128 subs Short throw shifter/Voodoo Knob ADR Revolution Rims Toyo T1S 215/45/17 Bassani Cat Back
Next Mod: SHO Y PIPE/Diablo Chip
Posts: 2,631 |
No probs, No CEL with just headers on in the garage  With the Catless Y on, I had no lights pop up to this day, Just my luck I will have one tomorrow now I did reset the computer. Took the NEG cable off the terminal for about 10 minutes. Presto, all good to go. And you???? Originally posted by BeJaxn: Merlin,
Thanks Brian
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 2,631 |
I see your looking at getting the off road Y! duuuuhhh
Merlin
Posts: 407 |
You'll never get a CEL without a main cat as there's no sensor AFTER the main cat to take a reading.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
