My A/C stopped working some time ago so I took it to the local dealership and, of course, they told me I needed $1200 worth of work to have it fixed. I passed. The accumulator has rusted through (big surprise).
I've got a new accumulator and picked up a used compressor from eBay. I see no reason why the compressor already in the car should be bad, but I got a backup just in case.
Ok, so I know I need to put in the new accumulator and replace the orifice tube (maybe), purge, charge, etc. What I'm wondering is that the service manual says that you must use a filter kit when the system has been opened. Is this really necessary? It requires a purge and fill, running the system, then removing the filters and purging and filling again.
Also, is it necessary or prudent to clean out the two lines running into the accumulator? It has been rusted out for about two years, so I'm afraid of what may have happened in there...
Finally, I haven't yet removed the dead accumulator, but if all the oil is gone, how much should I add to the system? Ford says 60 mL more than what was in it, but there is no spec in the service manual otherwise.
BTW, I'm not planning on doing all of this work by myself, so, yes, there will be a professional doing the appropriate parts. I'd just like to save on labor as much as possible.
Thanks for your help!
