Posts: 1,041 |
Which Oil does everyone prefer out there? Im sure this has been asked before, but apparently I was not watching :rolleyes: I use Redline 10W40... but I use to use Valvoline and noticed a difference on the change. Which do you guys use?
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Administrator
Administrator
Posts: 5,037 |
You're using 10W-40 in your SVT??????
That oil is way too thick for the oil passages and will cause oil starvation under a high load. Get that stuff out of there, and go to 5W-50!
Posts: 1,041 |
Posts: 1,041 |
I was told this should be fine, bast*rds... Thanks
Posts: 3,598 |
Just use Mobile1 synthetic. The only time I'd run redline, royal purple, or amsoil is if I was either running boost or open tracking my car. Otherwise you're dumping $$ into your oil pan.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 2,166 |
no... no... no need to get in an uproar.
Using 10-40 isn't going to hurt your engine, it?s just not the right oil to use. The higher the number the higher amount of heat your oil can stand. Also the thicker the oil gets. So if your engine doesn't run that hot, don't get such a thick oil. The thinner the oil it is, the better its going to protect your engine at start up.
I would stay away from Casterol Syntec oil, it contains high amounts of ash which will lead to high amounts of deposits. Really good oils are Redline (high amounts of silicon, good stuff for RX7s), Neo (handles high amounts of load, and high change intervals 12-24k), Amsoil (never tried this one, head lots of good things) and the ever so popular Mobil 1 my fav cause its the easiest to find and priced decently...
I use 10w30
Posts: 1,041 |
Posts: 3,598 |
Posts: 2,631 |
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 1,041 |
So when changed should it run a little better or what?
