Page 2 of 2 1 2
Originally posted by Joebob:
Has anyone had problems with warping rotors and Bendix brakes? I have Raybestos Quiet Stop ceramic pads and since installing them I have warped 3 sets of rotors. I can only assume that the pads are causing the problem.
Not if you're using a quality rotor like Autospecialty. Also bedding them in correctly. Helps not to stand on them from 100 to 0 either.
I've had my pads & rotors on for over 2 years.
The rotors did get a bit glazed after a year and a half but were not warped at all. That included 2 autocrosses and my normal daily hard driving.
When I had the car apart last fall I scuffed them up & cleaned them and they have been good so far. I can see they are glazing over again though.
Yes I am VERY hard on my brakes as I love to actually "drive" my car like it should be every time I get in it. Hundreds if not thousands of high speed stops too. (All that testing takes it toll)
I have noticed a hair of light "singing" when they are hot but only the last few seconds when coming to a complete stop. They never make a peep in normal or lightly spirited driving.
I think this is the best setup for the street or light track use.
If I had the "free" money I would get larger front brakes like what TCE sells. They would be my only upgrade choice over the much heavier BAER brake kits.
However this setup has certainly shown the limits of what the stock SVT setup can do. Very good performance for such a low price.
Bendix Titanium Metallic or Bendix CT-3 Ceramic. Whith is best?
SVT 99 #526 of 2760
WILL!
SVT 99 #526 of 2760
The Titaniums will be a better performing pad.
Standard ceramic pads are designed to reduce noise but the trade off is a softer pad material, more brake dust, and much less tolerance for cold & wet weather.
This is an intresting article for people wondering about warped rotors.
http://www.stoptech.com/whitepapers/warped_rotors_myth.htm
I have been happy with the bendix titanium on both vehicles I have put them on.
Green 2000 SVT #1166 mods-K&N and Custom heat shield, optimized y pipe, Magnaflow center resonator, DMDhttp://www.geocities.com/savinoss/Cars.html -Wifes car 99 Mystique V6 5 spd
Where can I buy the Bendix Titaniums? I have searched the web and cannot find anyone selling them for the Contour LX (front disc/rear drum).
'99 Contour LX 2.0L 4 Cyl Everything Stock
Joebob..look at the 1st post in the brake forum that is pinned up...
T-red E0 SVT ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
W
weargle Offline OP
W
Advance Auto has them on the shelf.
Whirling dervish of FFOG.
Page 2 of 2 1 2
Moderated by  Andy W._dup1
