I might be need ing a new engine soon. I want to switch to the 2.5. I recently had tranny replaced so I was wondering could I put in the 2.5 without changing my tranny
00 Civic SI Electron Blue Pearl tinted windows AEM cold air intake New to the stable: 95 white contour no mods (for now)
ATX Trannies are I believe the same, everything else will be a pain!!! Good luck!
5 Dr, 2.5 V6 Ghia X, 1999 Modifications:- Inventor of the inductive Secondary monitor Chrome grill JR cone air filter Black Diamond cross-drilled & grooved discs with Predator pads, ST200 throttle body, upper and lower extrude-honed intake manifolds Scorpion s/steel exhaust Current Project.. Building a ST200 powered MKI paullorman@btopenworld.com
I really don't want to get rid of this car because it is a fun to drive compared to the eclipse because it can hold more passangers. the eclipse is a 4 seater but for kids under 5 so I use the back seat as my trunk.
I am pretty sure you will have to change the trans,pcm,wiring harness and a mess of other stuff. It is not an easy trade. 4cylmys suggestion is the best solution for the swap.
99 SE Sport..ATX SVT exhaust SVT zip tube and air cleaner assembly Tinted windows 17" Cougar Zn Wheels
