Posts: 431 |
I love the fact the turbo builds 4 pounds of boost at 2500 rpms maybe more but I have a 4 pound spring now. I am seeing still white smoke coming out of the exhaust under a load or upper rpms never exceeded 5000 yet. I have 100 miles on the motor I am just so nervous because i don't know how a new motor can smoke under throttle. I did compression check and got 180 consistent through the engine. I have a brand new Turbo I have my drain line going down and to the side then back down but never up. I just don't know why it still smokes. I need some advice I also check the intake but no oil there.
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
Posts: 1,785 |
The only thing that I can think of is that you are getting a small amount of blow-by until the new rings seat.
This is completely a guess.
Are you using any oil?
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 431 |
Never checked oil today but I hoping it is the rings too
ported heads
13.2 @ 107 mph
Posts: 2,676 |
Burrita- Shouldn't you have waited for the engine to "break in" before adding the turbo? I'm putting at least 1000miles so the rings will set in before putting her on. . .
Posts: 4,713 |
You said you're running rich...just HOW rich? Do you think that's the source of smoke?
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 7,025 |
you wanna see rich...come check out my car. Were talking flames out the tail pipes rich!  Im in the same boat you are burrita. I gotta get this thing tuned.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,860 |
According to total seal the proper break in procedure is a steady load between 2500-3500 rpms for about 15 - 20 minutes. That's all
2001 Lincoln LS8
1994 Lexus GS300
Posts: 9,065 |
Originally posted by beyondloadedSE: you wanna see rich...come check out my car. Were talking flames out the tail pipes rich! Im in the same boat you are burrita. I gotta get this thing tuned.
{kontofosho}'s car is make you nauseous rich. Smells great at first...then you wanna go puke. Thing destroy's everything it goes against tho.
Flaming Biker Dude
Flaming Biker Dude
Posts: 1,502 |
white smoke is not rich....black smoke is rich...look at the rear bumper of my SR20DET powered 240 if ya wanna see rich.....
People suck.
Rev it till it MELTS.....
Posts: 1,336 |
White smoke is indicative of burn coolant ... a blown head gasket. However, white smoke can be very small amounts of oil as well. Blueish/white smoke is definitely oil. If it's possible to smell the fumes, that should tell you right away what it is. Perhaps have a family member drive the car while you trail them in something else???
