#952135 05/10/04 09:36 PM
2
2K SVT Offline OP
I need new tires for the Lexus and can't find the stock size in a tire I like. I did find the tire I like, but in a slightly larger size.
I am going from 215/45/17 to 225/45/17.
How much will this effect my odometer. I know my speed will be off about 1 mph, but can't find a calculator that will tell me miles.
Thanks
Jim 2000 Black Contour SVT...SOLD 2003 Lexus IS300, Silver, 5 Speed
#952136 05/10/04 10:40 PM
V
V
I don't think tire width will affect your speedo.
-Chuck Dienzo Black 98.5 E1 SVT #5022 of 6535 Born on March 16, 1998 "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
#952137 05/10/04 10:56 PM
225/45/17 is not only wider, but also taller than 215/45/17. Its deceptive because both list the height as 45, but you have to realize that that number is a ratio of the width, and consequently will be taller with a wider tire. You can go to tire rack or any tire manufacturer's website and see the spec for individual tires. It shouldn't affect your speedo more than a 1-2 mph at 60.
1999 Blk/Tan CSVT #654 - SOLD 2003 Suzuki SV650s
#952138 05/11/04 05:23 AM
Someone correct me if I'm wrong here (pertaining to my assumptions of how an odometer works & records mileage)...
215/45/17 diameter - 625.3 mm
225/45/17 diameter - 634.3 mm
*circumferences are of the same proportion
So your odometer should record [(625.3/634.3) x 100] = 98.58 miles for every 100 miles you travel.
Chris G. ~ 98 Mystique LS ATX
#952139 05/11/04 06:47 AM
V
V
Both of the above are reasons why I don't sell tires.
I didn't know about the whole width/diameter/flux capacitor ratio thing. I always figured 45 is a 45 is a 45. Go figure.
Thanks for the info.
#952140 05/11/04 07:51 AM
According to the infamous Miata tire size calulator, your size difference is 1.4% too slow. If the indicated speed is 60MPH, actual speed is 60.9MPH. Not like any of our speedos are accurate anyway. But the indicated speed will be lower than actual speed.
http://www.miata.net/garage/tirecalc.html
It was in the FAQ. Check it out next time.
2000 Contour SE Sport Originator of the Beowulf Headlight Mod and the Beowulf CAI
#952141 05/11/04 05:34 PM
and 225's tend to cause rubbing issues
Luke Pavlick Sales Representative ASE Certified Master Tech For more info on any post or to place an order please call 800-428-8355 ext. 362 for on-line orders mention my name in the previous contact field for prompt personal service. www.tirerack.com I want to die peacefully in my sleep Like my Grandfather Not screaming and frightened like the passengers in his car !!!
#952142 05/11/04 08:00 PM
He specifically asked about the ODOMETER. It was in his post. Read it thoroughly next time, all of you
#952143 05/11/04 09:22 PM
2
2K SVT Offline OP
Thank you for reading the entire post....5 stars for you Chris.
I hope your calculations are correct, becuase I'm way over my milage on my lease.
#952144 05/12/04 02:59 AM
Even on the lexus?
Moderated by  1314_dup1
