right. i am making the short ram, then heat shield. i guess you could say you can upgrade the existing short ram to the cold air as the cold air extension will connect to the maf directly. the cold air kit will have the short ram and the cold air extension. you can buy the cold air extension separately as well. and if you want a heat shield for the short ram i will design one and have it sent out for reproduction and then release those. so whos in on this?
