Page 3 of 3 1 2 3
do the magnecors only come in red?
Jim Hahn
1996 T-Red Contour SE
2002 Black Mazda MP5
Latest mods: sho shop off road y-pipe
No way do you have remove anything to get to the rear plugs (apart from the plug wires). It's a very simple operation with a ratchet, plug socket and extensions (maybe a universal, but I've never needed one).
I do believe you need to remove the coil pack to gain access to the rear plugs. Easy, 4 bolts, a plug and your done smile
Regards
1998 SVT Contour E1, Black
2001 Honda SuperHawk VTR1000F
"I bent my Wookie"
www.mamisano.com
I do my plugs without taking anything off the back. I use a wobble extension and it gets to that nasty one on the end. The biggest problem I had was getting the plug wire off because the last time I did a plug change I didn't use any grease on the boots.
96 SE
SVT exhaust
I got a set of Magnacors. Had trouble with keeping secured on the plugs. Would work fine for a day or so, then one would come loose and engine would start loosing power. Tried to crimp em down a little tighter and (oops) I messed up one of the wires. I guess I could order the one wire to replace it, but decided to go with the Ford wires. I just got the Ford wires today, been on back order for a couple of weeks. In comparing them to the Magnacors, the sparkplug boots on the Ford wires are much more flexible adn softer material than the Mag.s. This should help keep them down on the plugs.
FYI: Part# for Blue Ford Wires is:
M-12259-C625 List price is 49.95
If you want red change the "C" to "R"
yellow change the "C" to "Y"
98 evo 0 SVT
#2999 of 6535
Silver Frost/Midnight Blue
Lotsa bolt-ons
man you peopple must have lots of money to burn.. i mean magnecors are expensive as hell, and they dont even give you any performance increase (they wont ever) they are only spark plug wires, i say save the 1-200$ (or whatever) and but a real performance part (go buy some taylors, you will get the same "performance")
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
I have the FMS wires....I like them alot. I also have Bosch +4s. I did have Taylor wires, but decided to upgrade to FMS wires. If you do order the Taylor wires, be careful, when I first got mine, some of the wires didn't even make contact with the plugs. FMS are guarenteed to work.
--Matt
00' SVT Contour, Black and Blue #954 of 2150
Stock....
2003 Red Fire Convertable Cobra due in September...
I have the accel wires with the ngk plugs and msd ignition dis-4 and works good but acell i have had 2 sets that were bad so now i am going with the 9mm ford motorsport wires when i finally got the accel's to work they are good but to many problems and sets to get it right
1995 gl V-6
shaved trunk
lowered 16" rims.
custom one of a kind guages and i can get them if you like.
dyed interior painted dash.
ford 9mm plug wires.
bat inlet tube.
powdered coated intake.
msd dis-4 ignition
kkm air filter.
honed polished intake.
jet chip performance chip.
Ricer wing.
Page 3 of 3 1 2 3
