Posts: 163 |
I need advise on a very good set of performance wires and plugs. Any info anyone can share will be greatly appreciated.
------------------ 2000 SVT TRED #509 OF A BUILD OF 2150 K&N FILTER CHARGER MICHELLIN PILOT SPORTS 225/45/16 RICHBROOK SHIFTER RICHBROOK EBRAKE SPARCO PEDALS CARBONF. DASH KIT SONY XPLOD HU,FRONT PIONEER PREMIER 6.5 COMPONENT SET,REAR PIONEER 6X8 THREE WAY FUTURE MODS: CUSTOM SUPERTRAPP EXHAUST SHO SHOP Y PIPE 17 X 7.5 KONIG TOXINS
2001 MAXIMA ANNIVERSARY 5 SPEED, VISCOUS LSD K&N DROP IN SS CATTMAN YPIPE 5-ZIGEN HEIDFELDS 17X7.5 GOODYEAR HP ULTRA 245/45/17 THE BELOVED ONE MAYBELINE R.I.P. 2000 2000 SVT TRED #509 OF A BUILD OF 2150
Posts: 5,296 |
Magnecore wires with NGK plugs. But I'm broke, so I only have Taylor wires with Bosch +4 Platinum plugs. ------------------ AirKnight (Dominic Ho) Buffalo, NY
AIM: AirKnight on MTBMy BEAST
Posts: 3,237 |
Originally posted by AirKnight: Magnecore wires with NGK plugs. But I'm broke, so I only have Taylor wires with Bosch +4 Platinum plugs.
Same here, and I think they work just as well!
Posts: 230 |
I have the same setup without any gains that I know of it seems the same.I do get a little better gas milelage.
Posts: 7,329 |
You will need Double Platinum plugs. The Ingition system fires the spark straight through the block literally. Tip to electrode on firing side, electrode to tip or opposite side.
A single or non-platinum plug will were out extremely quickly.
Posts: 2,112 |
I have Magnecors with +4s. The Magnecors are the best, but they cost about twice as much as the competition. You have a couple choices with the spark plugs, but the +4s are the most durable.
Posts: 198 |
I installed the Bosch +4s in December and I was impressed with the smootheness of the engine at all RPMs. The mileage also got more consistant from tank to tank.
Last weekend I installed a set of Magnecor wires (BIG thanks to Joe at SPMotorsports!) and the engine was smoother running still. The bonus for me was that my install was halfway through a tank of gas and the nest itme I filled up and checked the mileage, it was about 1 mpg better. [I hope it stays that way!]
In summary, the wires and the plugs seem to be an excellent upgrade for the Duratech (I'll be checking how well they work on my wife's Mercury Villager as well; thanks again Joe Scott at SPMotorsports!).
Mike
1996 SE MTX, Desert Violet Blaupunkt Munchen, Dunlop Sport 5000s, Ray McNairy's THFix, custom air filter, Magnecor wires, Redline D4 tranny cocktail, 9005 lo-beams SVT-size front rotors, EBC Greenstuff pads all around
Posts: 618 |
I have Taylors and Bosch +4s. They seem to work very well! No gains that I can tell (maybe a little), but my '95 runs much smoother.
GOD BLESS AMERICA!!!
Ted tdavidk76@hotmail.com '95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX. Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods. Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
Posts: 4,528 |
I saw a Tour with Ford Motorsport plug wires at SZ. I wonder how much they are? They were even blue.
Posts: 618 |
Originally posted by todras: They were even blue. My Taylors are blue. They look really good with the Ford oval on the engine too!
