Page 6 of 15 1 2 4 5 6 7 8 14 15
#950206 05/10/04 01:02 AM
U
U
There comes a point and time when something is accomplished that will draw an invisible line in the sand and every 5 feet down that line, there is a sign that reads, "I dare ya!". And I think this is one of those times.
I can see many people just throwing their hands up in the air and saying out loud, "Oh forget it! I'll never be able to accomplish that!", but I also know that their will be a brave, lucky few that will say to themselves in a sly voice.... "PROJECT!"
Congrats Rick. Great job.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#950207 05/10/04 01:12 AM
Learned patience the hard way
The AEM Uego was simple to install. Just welded a bung before my center resonator and hooked the guage up to 12 volt power. I didn't trust the reading on the dyno as it showed me at 12.3:1 and my gauge read out at 11.1:1. I'm going to play with my SAFC and get my guage to reading better and go with that. They were having problems getting a good reading with my exhaust setup and the sensor type they had.
Demon, I'm running a 2.7x" pulley all ready. I think if I go smaller I actually will overspin the max rpm on the S/C.
Chris, you are getting the smaller core as that's what fits without any major problems and as you can see it all ready will support 400 hp which won't happen on your 2.5. I have only barely looked at fitting a larger core and that won't happen until late summer if at all.
In all I'm a little more than pleased with the final results and I know some minor tweaks will yield me over 400 pretty easily. I should also mention this dyno was on about 3 gallons of 1 year old 91 octane mixed with about 5 gallons of fresh 92. So a better fuel will also do me just fine.
Lastly, I've got to give some thanks to my wonderful wife who has given me 1000's of hours to spend in the garage and I wouldn't have been able to complete this project without her understanding.
Thanks,
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
#950208 05/10/04 01:53 AM
Understood, and I received your email.
Thanks.
Chris
PS: Keyser, how about that chip. Hint, Hint.
#950209 05/10/04 05:45 AM
I know.
I was just reminding Chris of a good way to overcome the minor pressure drop from the intercooler.
#950210 05/10/04 10:49 AM
Maybe you'll get that ellusive 400 hp pull here in Michigan Rick Either way, congrats on your numbers, truely amazing!, now get that damn thing into SCC magazine and make us all proud
#950211 05/10/04 11:20 AM
I'm still running the original jackshaft assembly (dated May 2002), so should I run a 2.87 or 3.125 pulley to keep the same psi after the intercooler (compared to no intercooler). I would be afraid of the shaft failing sooner than later.
#950212 05/10/04 12:16 PM
I'd run the 3.13 if you're currently running the stock pulley.
Rick
#950213 05/10/04 02:36 PM
How much $$$ did it cost you to reach 400hp,
If you don't mind sharing i understand.
Congrats on your project, very impressive
2004 Jeep Grand Cherokee Special Edition Blue Steel 99 Tropic Green SVT (Former Owner) #151 of 710 Born on 10/07/98 Have you driven a FRAUD lately?
#950214 05/10/04 02:42 PM
Rick I bet you were sweating bullets when you ran her for the first time - what with your unbelievable bad luck in the past. Congrats on this achievement!
BTW I see you're running the S-AFC. Hmmm, is the ECU fighting it? I'm having issues with high EGT's right now and am looking at doing something to adjust fuel (until Chris comes up here with his laptop!).
#950215 05/10/04 02:44 PM
I've got roughly 37,500 in everything, but that includes 3 motor builds and all the peripheral upgrades as well. This isn't just an engine, but engine, trans, suspension, ahh heck I'll let you guys look at the mod sheet and see:
Suspension Modifications
Koni Adjustable Struts
Eibach Lowering Springs front
H&R Lowering Springs rear
24 MM Aussie Bar- Rear Sway Bar
¼ Metal sway bar backing plates
Poly end link bushings
ES Motor Mount Insert
245/45/16 Yoko AVS Tires
5 MM spacers at wheels
Tubular Steel Adjustable Rear track arms
From Buckshot Motorsports
Energy Suspension Rear Control Arm, Front and Rear Sway Bar bushings
12.2? Superlite Brake kit from TCE Performance
11.25? Upgraded Rear Brake Kit from TCE Performance
Cryo Treated Brake rotors by 300 Below Inc.
Adjustable Front camber kit from BAT Inc.
Drivetrain & Performance Modifications
Buckshot Motorsports prepped 3 liter block
SVT Cams, w/ water pump drive removed
Cunningham Chrome Molly Rods with upgraded rod bolts
Diamond Racing 9.5:1 pistons with Total Seal piston rings
Clevite 77 rod & federal mogul main bearings
Dual Mode Mondeo Damper
SHO Shop lightened Billet Flywheel
Crank Knife Edged by Horn Race Engines
Engine Balanced by Midstates Machine
Crank, and rods cryo treated by 300 Below Inc.
3 Liter Heads Port & Polished with multi-angle valve job by BNM
Port matched UIM and LIM
SPEC Stage III clutch and pressure plate
2000 Model Year Transmission
HMS Inc. Mark III transmission update w/ full lube system & Zetec Final Drive Ratio
Quaife LSD installed by HMS Inc
Driveshaft Shop level III CV shafts
Cryo treated wheel hubs and studs
42 lb Ford Racing Injectors
Walbro 255 LPH fuel pump
MSD DIS-4 ignition Control
Water Injection Kit
Accusump 2 qt accumulator
Remote mount oil filter
Apex-I SAFC
Ford 9MM Plug Wires
B & M short Shifter
75 MM Pro-Flow MAF
65 MM Throttle Body optimized by
Buckshot Motorsports.
2.5? True Dual Exhaust w/ Magnaflow race series mufflers and crossover
Ford Chips tuned flip chip
Custom 1.75? Nickel Plated headers by MSDS Inc
Vortech Supercharger w/ upgraded shaft and 2.87? pulley
Secondary bearing block on cross shaft by
KnuKonceptz.com
Custom water to air aftercooler by Buckshot Motorsports
Autometer Phantom gauges including Oil Pressure, Oil Temp, Fuel Pressure, Boost/Vacuum and 5? monster tach w/shift light.
AEM Uego wideband O2 monitor
4 point Safety Harness
Dual Honed SVT upper intake
Trunk mounted Optima red top battery with remote disconnect
Derale Oil Cooler
Aesthetic Modifications
Buckshot Motorsports polished stainless sill protectors
Removed door ding guards
Foglights run w/o head lights
BNM Indiglo Gauges & HVAC Panel
Powdercoating of Various engine pieces by Buckshot Motorsports
Billet Pedal Kit including dead pedal
15% window tint
Body color matched grilles at all locations
Painted SVT Emblem at hood grille
Custom Front Fender Badging
SSR GT1 series 17? Rims street use
SSR GT1 series 16? Rims track use
PIAA 510 Driving Lights
Front Splitter by Mirko Racing
Sponsors
Brad Noon Motorsports
Cunningham Rods
MSDS Inc.
RAM Clutches
TCE Performance
300 Below Inc.
Wolfe??s Auto Body
Moderated by  mbb41_dup1
