Posts: 3,944 |
There comes a point and time when something is accomplished that will draw an invisible line in the sand and every 5 feet down that line, there is a sign that reads, "I dare ya!". And I think this is one of those times. I can see many people just throwing their hands up in the air and saying out loud, "Oh forget it! I'll never be able to accomplish that!", but I also know that their will be a brave, lucky few that will say to themselves in a sly voice.... " PROJECT!" Congrats Rick. Great job.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Learned patience the hard way
Posts: 2,454 |
The AEM Uego was simple to install. Just welded a bung before my center resonator and hooked the guage up to 12 volt power. I didn't trust the reading on the dyno as it showed me at 12.3:1 and my gauge read out at 11.1:1. I'm going to play with my SAFC and get my guage to reading better and go with that. They were having problems getting a good reading with my exhaust setup and the sensor type they had.
Demon, I'm running a 2.7x" pulley all ready. I think if I go smaller I actually will overspin the max rpm on the S/C.
Chris, you are getting the smaller core as that's what fits without any major problems and as you can see it all ready will support 400 hp which won't happen on your 2.5. I have only barely looked at fitting a larger core and that won't happen until late summer if at all.
In all I'm a little more than pleased with the final results and I know some minor tweaks will yield me over 400 pretty easily. I should also mention this dyno was on about 3 gallons of 1 year old 91 octane mixed with about 5 gallons of fresh 92. So a better fuel will also do me just fine.
Lastly, I've got to give some thanks to my wonderful wife who has given me 1000's of hours to spend in the garage and I wouldn't have been able to complete this project without her understanding.
Thanks, Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 1,625 |
Originally posted by Buckshot77: Chris, you are getting the smaller core as that's what fits without any major problems and as you can see it all ready will support 400 hp which won't happen on your 2.5. I have only barely looked at fitting a larger core and that won't happen until late summer if at all.
Understood, and I received your email.
Thanks.
Chris
PS: Keyser, how about that chip. Hint, Hint.
Posts: 9,602 |
Originally posted by Buckshot77: Demon, I'm running a 2.7x" pulley all ready. I think if I go smaller I actually will overspin the max rpm on the S/C.
I know.
I was just reminding Chris of a good way to overcome the minor pressure drop from the intercooler.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 9,196 |
Maybe you'll get that ellusive 400 hp pull here in Michigan Rick  Either way, congrats on your numbers, truely amazing!, now get that damn thing into SCC magazine and make us all proud
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 1,625 |
I'm still running the original jackshaft assembly (dated May 2002), so should I run a 2.87 or 3.125 pulley to keep the same psi after the intercooler (compared to no intercooler). I would be afraid of the shaft failing sooner than later.
Posts: 2,454 |
I'd run the 3.13 if you're currently running the stock pulley.
Rick
Buckshot77@msn.com
Posts: 680 |
How much $$$ did it cost you to reach 400hp, If you don't mind sharing i understand.
Congrats on your project, very impressive
2004 Jeep Grand Cherokee
Special Edition
Blue Steel
99 Tropic Green SVT (Former Owner)
#151 of 710
Born on 10/07/98
Have you driven a FRAUD lately?
Posts: 10,015 |
Rick I bet you were sweating bullets when you ran her for the first time - what with your unbelievable bad luck in the past. Congrats on this achievement!
BTW I see you're running the S-AFC. Hmmm, is the ECU fighting it? I'm having issues with high EGT's right now and am looking at doing something to adjust fuel (until Chris comes up here with his laptop!).
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,454 |
I've got roughly 37,500 in everything, but that includes 3 motor builds and all the peripheral upgrades as well. This isn't just an engine, but engine, trans, suspension, ahh heck I'll let you guys look at the mod sheet and see:
Suspension Modifications
Koni Adjustable Struts Eibach Lowering Springs front H&R Lowering Springs rear 24 MM Aussie Bar- Rear Sway Bar ¼ Metal sway bar backing plates Poly end link bushings ES Motor Mount Insert 245/45/16 Yoko AVS Tires 5 MM spacers at wheels Tubular Steel Adjustable Rear track arms From Buckshot Motorsports Energy Suspension Rear Control Arm, Front and Rear Sway Bar bushings 12.2? Superlite Brake kit from TCE Performance 11.25? Upgraded Rear Brake Kit from TCE Performance Cryo Treated Brake rotors by 300 Below Inc. Adjustable Front camber kit from BAT Inc.
Drivetrain & Performance Modifications
Buckshot Motorsports prepped 3 liter block SVT Cams, w/ water pump drive removed Cunningham Chrome Molly Rods with upgraded rod bolts Diamond Racing 9.5:1 pistons with Total Seal piston rings Clevite 77 rod & federal mogul main bearings Dual Mode Mondeo Damper SHO Shop lightened Billet Flywheel Crank Knife Edged by Horn Race Engines Engine Balanced by Midstates Machine Crank, and rods cryo treated by 300 Below Inc. 3 Liter Heads Port & Polished with multi-angle valve job by BNM Port matched UIM and LIM SPEC Stage III clutch and pressure plate 2000 Model Year Transmission HMS Inc. Mark III transmission update w/ full lube system & Zetec Final Drive Ratio Quaife LSD installed by HMS Inc Driveshaft Shop level III CV shafts Cryo treated wheel hubs and studs 42 lb Ford Racing Injectors Walbro 255 LPH fuel pump MSD DIS-4 ignition Control Water Injection Kit Accusump 2 qt accumulator Remote mount oil filter Apex-I SAFC Ford 9MM Plug Wires B & M short Shifter 75 MM Pro-Flow MAF
65 MM Throttle Body optimized by Buckshot Motorsports. 2.5? True Dual Exhaust w/ Magnaflow race series mufflers and crossover Ford Chips tuned flip chip Custom 1.75? Nickel Plated headers by MSDS Inc Vortech Supercharger w/ upgraded shaft and 2.87? pulley Secondary bearing block on cross shaft by KnuKonceptz.com Custom water to air aftercooler by Buckshot Motorsports Autometer Phantom gauges including Oil Pressure, Oil Temp, Fuel Pressure, Boost/Vacuum and 5? monster tach w/shift light. AEM Uego wideband O2 monitor 4 point Safety Harness Dual Honed SVT upper intake Trunk mounted Optima red top battery with remote disconnect Derale Oil Cooler
Aesthetic Modifications
Buckshot Motorsports polished stainless sill protectors Removed door ding guards Foglights run w/o head lights BNM Indiglo Gauges & HVAC Panel Powdercoating of Various engine pieces by Buckshot Motorsports Billet Pedal Kit including dead pedal 15% window tint Body color matched grilles at all locations Painted SVT Emblem at hood grille Custom Front Fender Badging SSR GT1 series 17? Rims street use SSR GT1 series 16? Rims track use PIAA 510 Driving Lights Front Splitter by Mirko Racing
Sponsors
Brad Noon Motorsports Buckshot Motorsports Cunningham Rods MSDS Inc. RAM Clutches TCE Performance 300 Below Inc. Wolfe??s Auto Body
Buckshot77@msn.com
