#947340 05/05/04 01:53 AM
Hey everyone... i'm looking for a sub with a high Qts, for IB use. The Lambda SB was perfect, as it has a Qts of over .5, but apparently Lambda's website isn't even working, and i'm not sure if i can even find any of these subs around.
The thing is, i'm looking for a 10" sub for as cheap as possible, with the Lambda type SQ. I've looked at the brahma, and that maybe a bit much for my taste... although it would be great. Anything with shorting rings, or Faraday would be lovely.
Anyone got any suggestions? Remember.. i need an awsome SQ sub that'll work IB. I really do want a Lambda though... the PB has too low of a Qts for me.
Remember this is why we're at war! I'm now officially a troll! 2004 Saturn ION QC with Sport Package AIM/AOL: animusshinigami
#947341 05/05/04 02:15 AM
It has to be a 10" sub? PE has still got their Dayton IB12's on sale for $85/each. What's your project Ren?
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
#947342 05/05/04 02:26 AM
I feel Guilty, Oh so guilty
Not a real high qts, but the SX10 at www.creativesound.ca would probably work quite well.
"If you are flammable and have legs, you are never blocking a fire exit" -Mitch Hedberg
#947343 05/05/04 10:00 AM
I guess i could go with that.. it has a nice xmax, so this is my best option for now..
Ren
#947344 05/05/04 11:20 AM
I think it is possible to do an inverse linkwitz transform to raise the effective Q. I'll see if i can find the schematic...
#947345 05/05/04 12:20 PM
Another question.. i'm debating between peerless , or Tangband
I wouldn't mind the TB as it seems to fit well for kickpanels.. but the Peerless has shorting rings
I wouldn't mind either one.. but i'm curious, as of which one would be better to match up with the Audax tweeters for now.. and the Hiquphons for later. I would go with Adire, but apparently the [censored] aren't out yet.
#947346 05/05/04 12:25 PM
It's going to be in the rear deck of my future car.. the Saturn ION. I'm going to take a long break from working with super custom setups, due to financial shortages. I even want to cut back from making enclosures. Anyways, what i've got planned is an ultimate SQ vehicle, for the least amount of money. I'd prefer the 10" as i want to keep things reasonable... Though i would, if i could, use a pair of Stryke AV's, if i had the time, and $$. Least amount of work, for the most amount of sound.
Basically, instead of $$ per watt.. it's time per how damn good it sounds.
#947347 05/05/04 12:31 PM
Anyways, I would go with the Dayton IB's.... except for the fact that i just have this need for the faraday. Anyways... that's all.
#947348 05/05/04 02:07 PM
Apparently there have been some issues with the TB. I would stick with the Peerless at this point.
#947349 05/06/04 12:18 AM
Now i'm stuck debating between the SX10 or the TC Sounds ultimate 10
the ultimate has a higher Qts, and Shorting rings. Also an xmax of 25mm one way. It's about the same price as well. The Fs is a bit higher though at 38hz. Not sure how that would affect the sound.
Ren
Moderated by  dnewma04_dup1
