#94612 04/27/01 04:09 AM
N
nick10 Offline OP
N
I would like to make close to 300-350hp @ the wheels in my svt which setup will get me that HP? turbo,supercharger or all motor.
Nick10@onebox.com
98 Svt/Silver frost
Reinforced engine mounts
B&M Shifter
KKM intake
custom exhaust
Stage 2 axles
Omp strut brace
Ground-control/koni suspension
Mirko front spoiler
Quaife "Waiting to be installed"
Pre 98 console
Until the 3.0l conversion can be supercharged that is probably not possible.
The 3.0L gives 240-250hp at the wheels and the supercharger gives similar numbers. Both cost around $3000-$4000. Install of a quaife LSD is also an important step as the stock diff may not be able to handle the power. That is another $1000. No turbochargers as of yet.
Josh
Aka Spectra SVT
02 Dark Highland Green F-150 XLT
Mods: Gunrack and cowboy boots
Supercharger is the only way to get there.
Get some custom rods & pistons and run some serious boost. Custom burned PCM with new injectors.
You might get 300HP at the wheels from the stock setup, but durability will be seriously compromised.
2000 SVT #674 - Check it out!
Bob King dyno'd with 296ish at the wheels with his supercharger and tweaking by Sho Shop. It is possible. Just add headers, ect...
Sincerely
Merlin
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
